quick brakes question
Old Sep 6, 2007 | 09:01 AM
COLKEOWN's Avatar
Default quick brakes question
yo
i did a rear disc brake conversion on my dx. just wondering do you need to change the master cyclinder? i just upgraded to 96 vti rear discs
Old Sep 6, 2007 | 09:03 AM
Probot's Avatar
Default Re: quick brakes question (COLKEOWN)
what year is your car??
but regardless for now, if you are 96+..i THINK you need to upgrade to the EX master cylinder..but i know for a fact you are going to need the 40/40 prop valve.
Old Sep 6, 2007 | 10:19 AM
BlueIntegraBoy's Avatar
You don't need a new master cylinder or prop valve. I've been in the same boat as you.
Old Sep 6, 2007 | 10:23 AM
Probot's Avatar
Default Re: quick brakes question (BlueIntegraBoy)
if the car doesnt come from factory with rear discs it does need a new prop valve
Old Sep 6, 2007 | 10:26 AM
Default Re: quick brakes question (Probot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote">if the car doesnt come from factory with rear discs it does need a new prop valve</TD></TR></TABLE>
I ran rear disks without a 4040 prop valve for a year without problems.
Old Sep 6, 2007 | 10:27 AM
Probot's Avatar
you wont have problems...you just wont get the right amount of brake fluid to the brakes in the rear to actually get any benefit of having rear discs.
Old Sep 6, 2007 | 10:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote">you wont have problems...you just wont get the right amount of brake fluid to the brakes in the rear to actually get any benefit of having rear discs.</TD></TR></TABLE>
I braked slightly better than the drums, however, the braking power change is insignificant unless upgrading the front. I upgraded the front a year later and changed the prop valve.
A rear disk conversion without the larger front disk is mainly bling.
Old Sep 6, 2007 | 10:44 AM
gsxr1k05's Avatar
i had a 90 crx that i did the swap in. you dont NEED to change the prop or master cylinder/booster. but it is better if you do. more firmer pedal. the prop valve is only importiant if you upgrade the master cylinder/booster. the 4040 is used with the integra master cylinder and booster cause they are larger than the stock dx ones
89efDUSTY
13
Mar 26, 2007 11:20 PM
alterdcreations
Sep 20, 2006 02:13 PM
accordOnVolks
Jun 30, 2005 10:38 PM
EGhatched
10
Mar 31, 2004 08:45 AM
AThiker
Mar 4, 2003 06:19 PM
