where to install oil feed and oil return lines.
Old Sep 6, 2007 | 04:10 AM
killamike0001's Avatar
Default where to install oil feed and oil return lines.
i am installing a turbo on a d16b7 and the only thing i am stumped on is where to tap for the oil feed and return lines. if anyhas a picture it would be appreciated very much.
Old Sep 6, 2007 | 05:13 AM
1995Civic's Avatar
Are you sure you dont mean the D15b7 motor?
The Oil feed taps into your turbo where there should be a threading for. The return line should have a thread at the bottom of the turbo and taps into you oil pan.
Old Sep 6, 2007 | 06:03 AM
Default Re: (1995Civic)
yes i meant the d15b7 (it was a typo). ok so i have learn the oil return line goes to the oil pan but where on the motor does the oil feed line run from.
Old Sep 6, 2007 | 12:00 PM
ej1sir16's Avatar
Default Re: (killamike0001)
IT DEPENDS ON YOUR KIT BUT IF YOUR KIT CAME WITH A CERTAIN ADAPTER THAT GOES IN BETWEEN YOUR OIL PRESSURE SENSOR THEN THATS WHERE IT GOES BUT IT HINK YOU CAN GET A SANDWICH PLATE THAT GOES IN BETWEEN YOUR OIL FILTER AND BLOCK AND IT COULD HOOK UP THERE
Old Sep 6, 2007 | 12:22 PM
stealthmode62's Avatar
Default Re: (ej1sir16)
http://www.stealthmodeperforma...shtml
gabe768
May 22, 2010 01:18 PM
Dre90
Apr 20, 2010 04:11 PM
Gtimportfanatic
Oct 31, 2007 09:06 PM
iperez
Jan 18, 2003 04:36 PM
MikeMAN
Jul 2, 2002 09:25 PM
