NEED HELP!!!!! for some reason it wont come off!
ok on the shift linkage the pin that holds it all together wont come out!!!! why the helll wont it!!!!! i need to get this motor out fast if you guys have any ideas that would be greatful!! and i tried to take the other side off but the bolt on that side is messed up to
suck it up and knock that bitch out. you have to use a punch, or bolt slightly smaller than the pin, and beat on that biotch.
Make sure the punch you are using is not an increasing diameter punch that goes in the pin. It has to be a flat tipped punch that is nearly the size of the pin. It is a PITA, but the first time is allways the hardest.
yes i sucked it up and hit it for like an hour last night with a hammer and a flat top punch, and it still will not come out
find a bolt slightly smaller, but one that doesnt fit inside of it, get some good leverage, and bang on it. that is the only way, and no one said it would be easy.
Good luck mang.
Good luck mang.
old faithful has never failed yet.............
I took a air chisel bit and ground it to 8mm with a flat end.........
BBBBRRRAAAAAAAAPPPPPPP.......ding....ding.....ding ....WTF did the bitch pin go now?
95EG2
Feb 28, 2010 03:38 PM
streetracerof06
Oct 27, 2005 09:20 AM
