200whp ls/vtec?
Old Sep 5, 2007 | 06:41 PM
skoodles2k6's Avatar
Default 200whp ls/vtec?
well i ben collecting a bunch of parts now to finaly throw a motor together for my ef hatch. im tryin to hit 200whp on pump gas wanted to see what some of you think cause theres not alot of people around here with this type of setup
b18b block .50 over
b16 pr3 .50 over pistons
Golden Eagle H-beam rods
ctr head
supertech dual valve springs/ titanium retainers
blox hsl cams
golden eagle ajustable cam gears
2layer head gasket
some uknown brand 4-1 header
things still needed
gsr/itr oil pump
gsr/itr water pump
the eagle h-beam rods.
not sure wich ecu ima run really shouldnt matter after i socket it and have huy at inline-racing tune it.
using a b16 tranny in a base model 91 ef hatch pretty gutted im lookin to get low 12s out of it lmk what you think.
Old Sep 5, 2007 | 07:11 PM
chippy's Avatar
Default Re: 200whp ls/vtec? (skoodles2k6)
i dont' think the golden eagles are needed. the stock ls rods will do.
Old Sep 5, 2007 | 07:52 PM
Default Re: 200whp ls/vtec? (chippy)
nah not when your reving it up 9k+ rod bolts tend to stretch after 8k on stock ls rods. and im also going for reliable here too.
Old Sep 5, 2007 | 08:36 PM
one slow coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skoodles2k6 &raquo;</TD></TR><TR><TD CLASS="quote">nah not when your reving it up 9k+ rod bolts tend to stretch after 8k on stock ls rods. and im also going for reliable here too. </TD></TR></TABLE>
thats why you use arp rod bolts on the ls rods. Take them to a machine shop and have them installed and have them resize the rods.
Also your going to need more power to hit low 12s. With 200 you will break into them but not low.
Also I dont think you can even put stock pistons on aftermarket rods without machining which is gonna cost you some $.
_kevin
Old Sep 5, 2007 | 10:00 PM
98vtec's Avatar
moderator emeritus
dyno it and find out. then post the graph in the dyno registry.
SiR Inspired ED7
Jul 29, 2006 08:31 AM
unix4linux
Apr 14, 2005 02:02 AM
Yellb16crxsi
May 18, 2003 02:52 PM
xmattoxx
17
Jan 12, 2003 01:47 PM
