Reverse problem...
Every day after I live my car sitting for a couple of hours, when I put it into reverse it chirps the gear (with the clutch all the way down). I checked the clutch hydro fluid and its right on the mark. Can anyone tell me whats going on.
Thank you
Thank you
1) I start the car
2) Press the clutch all the way down
3) Try to shift into reverse
And that is where I get a big *** chirp right after the chirp it shifts into the reverse...
That's it
That's it
hrmmz i some wat had the same issue. i missed da reversed and it made a weird noise. wat i did was pushed it hard towards da side, and when i bought da reverse down, i kinda pull it towards me, so it hookz on? ever since then i could alwayz reverse fine.. try experimenting
