motor trouble
Old Sep 5, 2007 | 03:24 PM
adidasklip's Avatar
Default motor trouble
ever since i installed my turbo kit, anytime the headlights or the radiator fan kicks on the car will bog in idle and idle very low, and if the fan is on and so is the headlights the car will almost stall imediatley......any suggestions to why that is?
Old Sep 5, 2007 | 04:05 PM
Schister66's Avatar
Man U FTW
does it idle lower than before?? When i first boosted, i had a low idle w/ the same problems you're describing...
Old Sep 5, 2007 | 04:09 PM
adidasklip's Avatar
Default Re: (Schister66)
oh yea alot lower almost to the point to where its gonna stall
Old Sep 5, 2007 | 04:18 PM
Boostfed's Avatar
New User
Default Re: motor trouble (adidasklip)
What is your idle rpm without the accesories on?
Old Sep 5, 2007 | 04:20 PM
Schister66's Avatar
Man U FTW
Default Re: (adidasklip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adidasklip &raquo;</TD></TR><TR><TD CLASS="quote">oh yea alot lower almost to the point to where its gonna stall</TD></TR></TABLE>
well there's your problem...now you just have to figure out why its idling lower
Old Sep 5, 2007 | 04:24 PM
adidasklip's Avatar
Default Re: motor trouble (Boostfed.com)
it idles at 1000 wen the fan kicks on it goes from 500 to 800 n wen fan and lights are on its 500 to 0
Old Sep 5, 2007 | 04:30 PM
Schister66's Avatar
Man U FTW
maybe your alternator is junk....i had a bad ground on mine and it didnt work so hot...
Old Sep 5, 2007 | 04:49 PM
adidasklip's Avatar
i was thinkn that either i need a new one or get a bigger altenator
Old Sep 5, 2007 | 05:04 PM
Schister66's Avatar
Man U FTW
you shouldn't need a bigger alternator...you're not putting more load on your electrical system
Old Sep 5, 2007 | 05:14 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">you shouldn't need a bigger alternator...you're not putting more load on your electrical system </TD></TR></TABLE>
Stock alternator should be fine. Check the voltage at your battery and alternator, see if the alt is ok
Old Sep 5, 2007 | 05:26 PM
b16a4's Avatar
Default Re: (Boostfed.com)
can the alternator cause a fluctuating rev?
2ndchirp
Oct 13, 2022 10:21 AM
hoytheld
Nov 6, 2013 04:55 AM
zach1288
14
Mar 26, 2007 03:56 PM
mrsuburban
Jan 5, 2006 02:55 PM
Blkcoupe
Oct 9, 2002 06:04 PM
