What cams are you running? ITR
Old Sep 5, 2007 | 02:53 PM
9civichatch3's Avatar
NICE GUY
Default What cams are you running? ITR
YES, I searched..
I recently picked up a 97spec JDM ITR longblock from Hmotors. I am in the process of getting aftermarket cams. My goal is to make around 200whp. I have BPi 3" v-stack intake, stock ITR IM, Hytech replica header, and 2.5" exhaust.
From what I have seen/heard Buddy Club Spec 3+, Skunk2 Stage 2, and RM M22X do well.
Do any of you have Dyno graphs or know where I can get some graphs of these cams on a ITR motor? Thanks
Old Sep 5, 2007 | 09:14 PM
NICE GUY
Default Re: What cams are you running? ITR (9civichatch3)
anyone?
Old Sep 5, 2007 | 09:48 PM
1.8L_allmotormilitia's Avatar
I would run buddyclub 3's.
Old Sep 6, 2007 | 07:49 AM
skata89's Avatar
im bout to run those with Import builders IM ported and polished, with 310cc injectors.
Old Sep 6, 2007 | 08:49 AM
bambam's Avatar
Default Re: (skata89)
BC4's or M22's get my vote if you don't mind running a thinner gasket to bump compression a bit. Otherwise, BC3+'s seem more ideal.
Old Sep 6, 2007 | 09:31 AM
DA_JDM's Avatar
Default Re: (bambam)
~12CR + JUN 3= POWER
Old Sep 6, 2007 | 10:46 AM
cartune network's Avatar
Default Re: (DA_JDM)
i run bc3's on a stock bottom end. i have a ported head and skunk2 valve springs with a few other mods and portmatched intake and what not. i made 216whp with it lol and the bc3's are still very easy to daily drive.
Old Sep 6, 2007 | 11:27 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9civichatch3 &raquo;</TD></TR><TR><TD CLASS="quote">YES, I searched..
Mysterious and hard to find dyno charts
More hard to find graphs!
Old Sep 6, 2007 | 01:17 PM
drive4aliving's Avatar
upgrade valvetrain, skunk2 stage 2 cams. and you're right there. u can get away with stock injectors and a 98+ Spec JDM 4-1 ITR header. dont run a cat either
Old Sep 6, 2007 | 01:58 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">~12CR + JUN 3= POWER </TD></TR></TABLE>
yeah you can run jun3s on stock bottom end easily and make decent power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network &raquo;</TD></TR><TR><TD CLASS="quote">i run bc3's on a stock bottom end. i have a ported head and skunk2 valve springs with a few other mods and portmatched intake and what not. i made 216whp with it lol and the bc3's are still very easy to daily drive.</TD></TR></TABLE>
you could probably make a little more with some larger cams. bc3+ arent really that large of a cam
Default Re: (drive4aliving)
or invest in better parts like maybe a hytech, smsp, or a toda header and not some weak header. and if u wanna run a cat i would reccomend the hytech high flow cat cause it flows really good and ull burn cleaner than stock. i wouldnt run stock injectors either cause ur gonna max them out really quick and u dont wanna be at a 96% duty cycle so i would say get some 3xx cc's or some 440cc's. and make sure u have a true 2.5" inner diameter exhaust. the better quality of parts the more power and reliable power u will make.
itr 4-1 headers are cheap for a reason. if u really wanna take advantage of the larger cam profiles get a port and port match ur intak manifold and get a 68mm throttle body and port match the opening on the intake mani aswell and ull be well above 200whp. just my .02 if ur gonna do it right, do it once and dont skimp out on parts.
Old Sep 6, 2007 | 05:08 PM
NICE GUY
Default Re: (cartune network)
thanks guys.
I guess its btwn. the BC Spec3+ and S2S2
Old Sep 6, 2007 | 06:03 PM
SkankyEJ7's Avatar
Default Re: (9civichatch3)
rm22x or bc4's, or blox type c's, or even pro 1's. those are the ones i would personally choose
408EJ1
29
Apr 2, 2011 08:51 AM
CivicEG6-R
Nov 3, 2005 08:44 AM
hatchbackhonda
May 2, 2004 09:55 AM
Gabe_
12
Dec 29, 2003 11:51 AM
B16Hatchcx
Dec 24, 2003 02:20 PM
