clutch/trans problems
Old Sep 5, 2007 | 02:48 PM
pat92si's Avatar
Default clutch/trans problems
Hey guys I have a 97 civic cx hatchback with a 2000 B16 and recently ive had problems getting into 1st gear at stops.
I replaced the slave cylinder thinking that was it but it didnt work. any ideas on what it could be, the master cylinder is a possibility but im not sure.
Old Sep 5, 2007 | 03:07 PM
MasterShake's Avatar
gear oil? does it go into any other gear at a astop?
Old Sep 5, 2007 | 06:34 PM
pat92si's Avatar
Default Re: (MasterShake)
I just did a trans fluid change 3 weeks ago and i checked the fluid, no metal shavings and it was perfectly clean.
Old Sep 5, 2007 | 06:37 PM
drtysohc's Avatar
Did you put Honda MTF back in it, or something else?
Old Sep 6, 2007 | 01:21 PM
pat92si's Avatar
Default Re: (drtysohc)
Honda MTF, but even if it was a different fluid i don't think it would have an effect like this.
Old Sep 6, 2007 | 02:25 PM
slowcivic2k's Avatar
Default Re: (pat92si)
Just for future reference, always test the clutch disc on the input shaft before install, sometimes burrs can make the disc stick to the shaft. Was the rust (if any) cleaned off the input shaft before the install? And are you sure the clutch lines are fully bled?
Hold in the clutch for about 5 seconds or so from a stop, and then try to shift, and see if it still grinds. If it does, I would suspect the clutch disc hanging up on the input shaft.
Old Sep 6, 2007 | 06:31 PM
pat92si's Avatar
Default Re: (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Just for future reference, always test the clutch disc on the input shaft before install, sometimes burrs can make the disc stick to the shaft. Was the rust (if any) cleaned off the input shaft before the install? And are you sure the clutch lines are fully bled?
Hold in the clutch for about 5 seconds or so from a stop, and then try to shift, and see if it still grinds. If it does, I would suspect the clutch disc hanging up on the input shaft.</TD></TR></TABLE>
alright thanks ill try that out, come to think if it though there might have been a small amout of surface rust on the input shaft before i put it in the car.
sipolt89
Transmission & Drivetrain
Dec 10, 2008 04:13 PM
hpimichael02
Oct 31, 2008 09:46 AM
HokieinCville
Feb 15, 2007 11:46 AM
GSR4door1
Jun 12, 2004 05:34 PM
mjb240z
Dec 18, 2003 09:55 PM
