h22a4 build
Old Sep 5, 2007 | 02:42 PM
sean-sports's Avatar
Default h22a4 build
i was wondering can you get a h22a4 block with no atts im doing a h2b setup thats why i ask and can i throw a h23 crank and rods in the block does any one know what kind of pistons would fit perfect someone told me f20c pistons i know the h22 stick out a little
Old Sep 5, 2007 | 04:55 PM
E-Money's Avatar
Default Re: h22a4 build (sean-sports)
you can get a h22a4 block without the atts. just stick with the h22 internals..
Old Sep 5, 2007 | 07:29 PM
JDM JEFFREY's Avatar
Default Re: h22a4 build (E-Money)
why only h22 internals?
Old Sep 7, 2007 | 11:38 AM
alterdcreations's Avatar
Default Re: h22a4 build (JDM JEFFREY)
98 + h22 block
f23 crank and rods
f20c pistons
97 pre h22 block
h23/f22 crank and rods
any h22 piston
Old Sep 7, 2007 | 02:06 PM
97LXF20B's Avatar
Default Re: h22a4 build (alterdcreations)
werd... h23 crank and rods is the perfect budget stroker kit.
Old Sep 7, 2007 | 05:55 PM
h22_SOL's Avatar
if you use a f23 crank
is their any custome fab that needs to be done to make it work properly?
or it fits in perfectly and u dont have to wrry bout anything..
Old Sep 7, 2007 | 05:58 PM
AllMotorRandy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">98 + h22 block
f23 crank and rods
f20c pistons
97 pre h22 block
any h22 piston </TD></TR></TABLE>
do the f20c pistons have the same compression height as h22 pistons?
Old Sep 7, 2007 | 06:08 PM
h22_SOL's Avatar
Default Re: h22a4 build (AllMotorRandy)
i think its better.
Recklessnenito
Engine Machining & Assembly
Jun 4, 2018 08:41 PM
Recklessnenito
Jun 4, 2018 07:15 PM
darvin
Apr 10, 2006 08:03 AM
912
Mar 9, 2006 12:10 AM
JDM_COUPE
May 7, 2005 09:10 PM
