tuning question vafc2 plx r-300 a/f ratio
Hello h-t community. I have an issue. My car needs to be tuned. Currently I have a vafc2. I am thinking about buying a plx r-300. Now my major question is do i need a dyno to tune with the vafc2 and the plx r-300. I am just tuning for a/f right now with my basic bolt ons (4-1 header, blox im, intake, 3" custom exhaust, minor port and polish). Do I need to dyno tune? or can i just tune for 14.7 a/f. I have never tuned using the vafc before. I have taken it to someone but now they charge $400 which happens to be the price of the plx r-300. I am good with computers and math so I am fairly confident i can do this on my own. now with the plx r-300 and the vafc2 will i have good success or should i just take it to the dyno. The plx has datalogging so it seems like i could drive and tune later. Another reason why i like this route is because in the winter when the temps drop i could retune based on my wideband readings, basically i could tune based on conditions. if i take it to the dyno and spend 400 for them to tune I would be out 400 and if weather conditions changed i could tune it on my own. Id appreciate any good advice. I am in an obd2 vehicle so im not messing with the timing too much. thanks again h-t.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madlion »</TD></TR><TR><TD CLASS="quote">do i need a dyno to tune with the vafc2 and the plx r-300.</TD></TR></TABLE>
You don't need one, but it's the only real way to determine whether or not you've achieved the optimal settings for your engine. Tuning for a general A/F range can get you close, but the specific A/F ratio that's ideal for one engine at a given RPM won't necessarily be ideal for another.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madlion »</TD></TR><TR><TD CLASS="quote">can i just tune for 14.7 a/f</TD></TR></TABLE>
Stoich is too lean under load. Most N/A tuners will generally tune somewhere in area of 13:1 for WOT/high-load conditions, but again, the good ones know that there isn't necessarily a magic A/F ratio that will yield the most power.
Beckerton
Engine Management and Tuning
14
Jun 30, 2010 10:35 AM
