searched but couldnt find!!!!
i have a z6 head that i'm planning on mating with my y7. i was wondering if i can just put the z6 intake manifold using the stock injectors and fuel rail, are any other modifications needed?
woah i just confused myelf, hopefully you guys will understand.
ok i am assuming the car has the y7 meaning it is obd2x
so you can use the mani, you will need to convert to a 2 wire iac, change the injector clips, and thats all i can think of right now. you can re pin the dizzy.
now in order to convert to a z6 mani how do i convert the iacv to a 2 wire and change the clips to what? oh and how about that whole re-pining the dizzy????
sorry im so noob at this
idk if the y7 dizzy will work with the z6 head. the y8 may.
what ecu are you using?
look for bauleycivic's writeup on the mini me.
only mini me i have ever done was putting a y7 into an already blown up y8. the car was already an ex so the swap was easy.
remember to take out the oil jet also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foowitdaredek »</TD></TR><TR><TD CLASS="quote">well im not gonna do the mini me yet... i just wanna change the intake manifold...as for the ecu i have the stock p2e but i do have the p28... but no jumper harness.</TD></TR></TABLE>
ok you will need to convert to a 2 wire. basically you need a 2 wire iacv connector, use the 2 that match, terminate the other.
also you need to swap a wire on connector A cant remember that either ill look later. man im lazy today. he hee. but you will need a jumper for the p28.
https://honda-tech.com/zerothread?id=1018993
https://honda-tech.com/zerothread?id=735196
https://honda-tech.com/zerothread?id=554053
https://honda-tech.com/zerothread?id=1635057
If you had looked in the index at the top of the forum this thread could have been entirely avoided.
thanks i actually have a couple of those as bookmarks...except the one with the intake manifold....pics dont work and thats really looking for z6 mani onto y7 head. but thanks anyways
Crosseman
Jan 14, 2015 05:29 PM
blknpurple
28
Feb 18, 2013 04:44 PM
uindaway
Nov 12, 2012 01:25 AM
SHG_Beans
Jun 19, 2006 04:55 AM
drewboy
Jun 24, 2005 01:31 PM
