ZC in a crx question
Old Jun 15, 2002 | 11:44 AM
Soled Out's Avatar
Default ZC in a crx question
did a search, no results, me and a friend are plannin to do a zc in his 89crx HF, i need to find a site that shows ALL steps on how to do this swap, since we've never done it(wiring, ecu, axles, tranny..etc.) any positive info would be appreciated, please do not tell me to do a b series swap, thanx! ...also what tranny would be best, we plan on boosting it in the future, ZC or SI trans?
[Modified by civic htchbox, 3:46 PM 6/15/2002]
Old Jun 15, 2002 | 12:49 PM
Soled Out's Avatar
Default Re: ZC in a crx question (civic htchbox)
so many ppl with zc swaps, yet no one knows?
Old Jun 15, 2002 | 02:26 PM
allmotorEG-SI's Avatar
funny how it works like that huh.
i doubt there is a step by step website other wise someone would have posted it already.
Old Jun 15, 2002 | 04:49 PM
Soled Out's Avatar
Default Re: ZC in a crx question (CAMAROCRUSHER)
what needs to be done for wiring with this swap??????
Old Jun 15, 2002 | 05:07 PM
Mr.JaCkeL26's Avatar
i wana do the same thing since i cant afford a b series motor . but i think as far as the wiring goes, you have to get a new harness, i think. i know for sure if you get a dohc zc. but i dont know if you have to switch the harness for a sohc. sorry man thats my .02 cents! wish i knew more!
Old Jun 15, 2002 | 05:15 PM
02WRX's Avatar
Default Re: ZC in a crx question (GsRHaTch)
i don't know all the changes needed for a hf wiring harness, but it were a si harness, the only change would be for the cylinder position sensor, which is located on the exhaust cam.
i think that hasport.com may have some of the wiring changes you need to do - if the hf/dx share the same wiring, then you can check the dx wiring for a b-series drop, then take care of the cps wiring.
eric
Old Jun 15, 2002 | 05:18 PM
Civicboy's Avatar
http://www.hasport.com/88-91_ZC_Swap_Tech.htm here is a little more info
Old Jun 15, 2002 | 05:26 PM
AMChev's Avatar
http://www.geocities.com/civiczc/zcswap2.html
Old Jun 15, 2002 | 06:07 PM
Soled Out's Avatar
Default Re: ZC in a crx question (cspu)
what we plan on doing is ordering the setup from nippon-motor for 950, motor, trans, ecu, etc. im not sure what ecu u get with that though, and if its plug and play? Sorry, im new to all this ecu wiring junk.
Old Jun 15, 2002 | 06:39 PM
Soled Out's Avatar
awesome site, thanx a bunch, but what about after phase two? it just stops right there on that site and doesnt show u the rest of ur swap???
CW96
Jan 2, 2007 12:56 PM
90b20b4
Jun 27, 2005 02:43 PM
the niz jiz
11
Sep 30, 2004 05:50 PM
91CRXpusher
Jul 26, 2003 09:16 AM
slowman
Jun 17, 2002 11:55 AM
