Help...wiring..what's this
Old Jun 15, 2002 | 11:35 AM
TodaSi's Avatar
Default Help...wiring..what's this
This is a 92 Civic CX and the plug in the picture comes off the main harness and has a white plug blocking it off. It's sitting on the passenger side by the air intake hole. Any idea what's it for? I can't find it in my Helms manual.
Think either it's for VTEC or ABS.
[Modified by TodaSi, 3:42 PM 6/15/2002]
Old Jun 15, 2002 | 01:11 PM
slomofo's Avatar
GDD Member
Default Re: Help...wiring..what's this (TodaSi)
Just leave it there. Every 92-95 has it.
Old Jun 15, 2002 | 01:25 PM
JV's Avatar
JV
Who?
Default Re: Help...wiring..what's this (slomofo)
It's definitly not for VTEC......
Old Jun 15, 2002 | 01:27 PM
slomofo's Avatar
GDD Member
Default Re: Help...wiring..what's this (JV)
It's not for ABS either. Take the white thing off and look at the plug. Everytime I open my hood, I always take the white cap off and try to figure out wtf that is for.
Old Jun 15, 2002 | 01:56 PM
CHONCH's Avatar
its neither vtec or abs. a CX hatch nas neither. although, some cx's were pre-wired for vtec, but im not sure which ones. i think that is a diagnostic port for one of the car's systems. not sure though.
later
Old Jun 15, 2002 | 02:31 PM
tvrsir's Avatar
Default Re: Help...wiring..what's this (twinturbobb)
the plug i think would be the a/c condenser, evap, and the fan. i would say since the cx doen't come with a/c
Old Jun 15, 2002 | 02:39 PM
Honda4CX-T's Avatar
Default Re: Help...wiring..what's this (tvrsir)
It is used to connect your A/C Wiring Harness, when you decide to install A/C
Old Jun 15, 2002 | 02:41 PM
JV's Avatar
JV
Who?
Default Re: Help...wiring..what's this (Honda4CX-R)
Yep, just went and looked at my car. I took the AC out but the wiring is still there.
Old Jun 15, 2002 | 04:06 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Toda Si, did you ever figure out how to re-do your distributor?
I found out a better way to explain it.
The 2 wires that need to be moved are the coil wires.
The OBD2 distributor has the coil wires all in the same plug as the other 4 wires, but your Civic's engine harness has a separate plug just for the coil wires.
Simply unhook the 2 coil wires (can't recall color:hammer and then hook them into the "extra" plug for them that your CX harness has on it.
Does that make sense?
BTW:
Just don't worry about that little white-capped plug...doesn't have any effect on the swap y0!
...Unless you need A/C.
Old Jun 15, 2002 | 04:33 PM
SlowB16's Avatar
Default Re: Help...wiring..what's this (B18C5-EH2)
Could it be a plug for city lights?
Old Jun 15, 2002 | 10:30 PM
TodaSi's Avatar
Default Re: Help...wiring..what's this (SlowB16)
Thanks everyone, I figured out what the plug was for yo....
Gonna hook the neon lights up to it and bump with some hydralics boyz
On a more serious note: The rear engine mount bracket (GS-R)does not fit on my block(different bolt points)....my 99 Si bracket does fit but is about 1" short. Is the type R rear bracket different from the GS-R, as I have an ITR block?
Tom, yea, was easy to figure out, but I just hooked up the OBD-1 distributor.
[Modified by TodaSi, 2:32 AM 6/16/2002]
Old Jun 16, 2002 | 01:19 AM
rocket90's Avatar
hey i have that plug too... what is it for?
Old Jun 16, 2002 | 12:10 PM
TodaSi's Avatar
Default Re: Help...wiring..what's this (rocket90)
I guess it's for air conditioning.
Dekorum
18
Jun 18, 2010 07:09 PM
motrayEG6
Aug 4, 2009 09:48 AM
hennessy
Aug 19, 2007 07:55 PM
Fighterinsnatch
Dec 27, 2006 08:02 PM
THC07
Jan 18, 2006 12:06 AM
