Poping Out of Gear?
Old Sep 5, 2007 | 04:17 AM
DETOUR180's Avatar
Default Poping Out of Gear?
I switch a new clutch kit and flywheels in a LS hydro tranny but now having problems with 4th gear poping out? What could it be? I also switch the shift bushing too.
The shifting feels different now in 2nd and 4th because it seem short or barely pass neutral but 1st,3rd, 5th gears are fine. Share you view on tranny problems and why it might not go into gear all the way thanks.
Old Sep 5, 2007 | 06:04 AM
kin413's Avatar
Default Re: Poping Out of Gear? (DETOUR180)
well i dont know much but it happend to me once when i first swapped my car..it was tranny fluid that i was missing...
Old Sep 5, 2007 | 06:11 AM
Probot's Avatar
Default Re: Poping Out of Gear? (kin413)
yea id say try changing the trans fluid and see if it helps at all
Old Sep 5, 2007 | 06:12 AM
instructor74's Avatar
Are you sure that yoou got everything back together the right way? Is there any binding in the shifter linkage? Can you get the car into Rev?
Old Sep 5, 2007 | 06:44 AM
Bense's Avatar
https://honda-tech.com/zerothread/1916635
Old Sep 5, 2007 | 08:18 AM
DETOUR180's Avatar
It drive fine. I pour 4 qt of tranny fluid and it pretty much work good accept it feels weird on 2nd and 4th just pop out into neutral. The car rev fine too the only problem is 4th gear.
The tranny was good. All that was done was a change of clutch kit and flywheel.
I will check the linkage again when i get a chance. Thanks guys.
Old Sep 5, 2007 | 08:26 AM
Probot's Avatar
Default Re: (DETOUR180)
hmm...if you took it to a mechanic, bring it back and tell them what is going on and show them. - if you did it yourself..id bring it to a mechanic and tell them what is going on and show them.
Old Sep 5, 2007 | 05:41 PM
DETOUR180's Avatar
Default Re: (Probot)
yeah. if i could fine time and price quote then i will take it in if not then i have to take off the tranny again and see.
Old Sep 5, 2007 | 06:03 PM
Thateguhate's Avatar
you change the dial? its supposed to be changed everytime your take apart the tranny. Also, mine did the same **** aside from closer gears.. Turned out there were missing parts when they put it back together.. mine popped out in first gear, i literally had to hold it in till i was ready to shift into second.
Old Sep 5, 2007 | 06:14 PM
f22beast's Avatar
Make sure all the bolts are back in the mounts. I took my tranny apart to do my input shaft bearing and didn't put the two bolts back in the rear mount. Made shifting feel diff. and the gear shift would seem to get caught going through neutral. Also made my exhaust shake alot. Threw two bolts back in the mount and all problems went away.
Old Sep 5, 2007 | 09:21 PM
forcefedferio's Avatar
Default Re: Poping Out of Gear? (f22beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DETOUR180 &raquo;</TD></TR><TR><TD CLASS="quote">It drive fine. I pour 4 qt of tranny fluid and it pretty much work good accept it feels weird on 2nd and 4th just pop out into neutral. The car rev fine too the only problem is 4th gear.
how about, too much fluid. i believe they take 2.9 quarts...if you fill it through the VSS (which im assuming you did since you managed to stuff 4 quarts in) then drain it with the drain plug on the tranny, put the drain plug back in and remove the fill plug, fill the transmission up with fluid through the VSS hole until fluid comes out of the fill plug hole, thats when you know you have enough fluid.
Old Sep 5, 2007 | 10:16 PM
ejoner's Avatar
Default Re: Poping Out of Gear? (forcefedferio)
4 quarts? You put 4 quarts of oil in the engine not the transmission. it usually takes 2.5/2.9 quarts of 10w40 or 10w30. Thats why its poping out of fourth.
Old Sep 6, 2007 | 08:19 AM
Default Re: Poping Out of Gear? (ejoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner &raquo;</TD></TR><TR><TD CLASS="quote">4 quarts? You put 4 quarts of oil in the engine not the transmission. it usually takes 2.5/2.9 quarts of 10w40 or 10w30. Thats why its poping out of fourth.</TD></TR></TABLE>
honda manual transmission fluid....10w40 or 10w30 as a last resort.
Old Sep 6, 2007 | 08:29 AM
Bense's Avatar
it's popping out of fourth because your gears are worn out. if you grind your gears long enough they stop working. Just like I explained in the link that I referenced earlier.
Old Sep 6, 2007 | 01:49 PM
DETOUR180's Avatar
YES honda manual fluid. i never have any gear problems until i change the clutch kit. alright i will look into it this friday and if things dont go well it while have to go into the shop. Thanks.
Charlie Moua
Jul 28, 2009 05:51 PM
qazaq
Sep 7, 2006 04:34 AM
WhiteVX
May 19, 2006 04:37 PM
fangtl
Oct 4, 2003 06:19 PM
i HAVEtheADVANtage
17
May 28, 2003 10:58 PM
