Skunk2 Pro-S damper assembly question
Old Sep 5, 2007 | 12:14 AM
LeArN2LiVe's Avatar
Default Skunk2 Pro-S damper assembly question
Modified by LeArN2LiVe at 12:16 AM 9/12/2007
Old Sep 5, 2007 | 12:24 AM
bmoua's Avatar
https://honda-tech.com/zerothread?id=1078663
Old Sep 5, 2007 | 05:37 AM
Endo-land's Avatar
Isnt the pro-s a full coilover with pillow mount that should just replace the whole shock/spring assembly.
Old Sep 5, 2007 | 08:29 AM
Crx_Civic's Avatar
Default Re: (Endo-land)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Endo-land &raquo;</TD></TR><TR><TD CLASS="quote">Isnt the pro-s a full coilover with pillow mount that should just replace the whole shock/spring assembly.</TD></TR></TABLE>yea but it dosnt come with the spring on the shock........the ring is to keep the nut that ur spring sits on from moving. not sure on the bump stop (by the way you void the warrenty on the skunk2 if u cut that) i just stuck mine on with the small side towards the bottom...seems to work. i havent looked at it but it should stay at the top(or bottom) once you've drove it some.??
DB1_559
Suspension & Brakes
May 18, 2008 03:27 PM
talijan
Apr 21, 2008 04:41 PM
LBBP R
Dec 29, 2004 09:34 PM
bloxp1vtec19
Jun 28, 2004 05:40 PM
