Skunk2 Pro-S damper assembly question
Re: (Endo-land)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Endo-land »</TD></TR><TR><TD CLASS="quote">Isnt the pro-s a full coilover with pillow mount that should just replace the whole shock/spring assembly.</TD></TR></TABLE>yea but it dosnt come with the spring on the shock........the ring is to keep the nut that ur spring sits on from moving. not sure on the bump stop (by the way you void the warrenty on the skunk2 if u cut that) i just stuck mine on with the small side towards the bottom...seems to work. i havent looked at it but it should stay at the top(or bottom) once you've drove it some.??
