smokin h22 in v-tech
Old Sep 4, 2007 | 04:37 PM
hondick14's Avatar
Default smokin h22 in v-tech
2000 prelude, 90k on motor, runs great, uses 1 quart of oil every 150 miles, running super rich, no smoking till v-tech is engaged, very bad, huge cloud. Stock ecu, 02 sensors test good, stock internals? any suggestions?
Old Sep 4, 2007 | 04:45 PM
street_ride14's Avatar
Default Re: smokin h22 in v-tech (hondick14)
Yeah ... get off the VTEC bottle, nitrous is more safe.
Old Sep 4, 2007 | 04:47 PM
dagle's Avatar
Default Re: smokin h22 in v-tech (street_ride14)
what color is the smoke? and when was maintenance?
Old Sep 4, 2007 | 05:41 PM
plikit's Avatar
check your spark plugs and let me know what they look like. i had similar symptoms. if your plugs are covered in oil i'll elaborate on what my problem was.
Old Sep 4, 2007 | 06:24 PM
WhiteBB2's Avatar
Default Re: smokin h22 in v-tech (plikit)
its VTEC!
NOT V-TECH...
Old Sep 4, 2007 | 07:24 PM
hondick14's Avatar
black and blue, in know it is rich and i know it is using oil. I have run a compression test, passed, leak down test, passed. new t-belt, plugs, wires, cap, rotor, cleaned injectors and intake, cleaned egr ports, replaced valve guide seals. The part that is confusing me is, why it only smokes in v-tec, excuse the incorrect spelling earlier. I have stumped many a master mechanic with this one, i only have guesses. Trying to see if anyone else has had this problem. no oil on plugs, just carbon build up. I am thinking bent valves or cracked piston.
Old Sep 4, 2007 | 07:27 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondick14 &raquo;</TD></TR><TR><TD CLASS="quote"> I have stumped many a master mechanic with this one, i only have guesses.</TD></TR></TABLE>
They are probably wondering why your VTECH!!!!!!!!!!!!phone is smoking
Old Sep 4, 2007 | 07:33 PM
guessman's Avatar
have you done a compression test yet?
Did you do anything to the engine when you got it? (rebuild/head gasket only)
know anything about the history of the engine? (how many miles were on the engine when you got it?)
how are the valve seals?
sounds like when it kicks in the V-tec (of course more pressure is placed on the oil) and that has to go some where, just a thought.
Old Sep 5, 2007 | 08:11 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondick14 &raquo;</TD></TR><TR><TD CLASS="quote">2000 prelude, 90k on motor, runs great, uses 1 quart of oil every 150 miles, running super rich, no smoking till v-tech is engaged, very bad, huge cloud. Stock ecu, 02 sensors test good, stock internals? any suggestions?</TD></TR></TABLE>
Save your money for a REBUILD or JDM motor....your engine is FUBAR'd....
How do people keep making the VTECH mistake when its SPELLED VTEC on your car at least once.......This tells me you have never popped the hood before.
x_40oz
Dec 16, 2013 07:24 AM
Theroy
Honda Civic (2001 - 2005)
Dec 12, 2011 03:23 PM
uncleben
Jun 3, 2005 11:21 AM
Mar_DC2
Feb 5, 2005 04:10 PM
Loveless
May 26, 2003 01:16 AM
