98+ spec jdm type r still stuck with CEL
Old Sep 4, 2007 | 01:54 PM
alien's Avatar
Default 98+ spec jdm type r still stuck with CEL
i just put in a brand new second o2 sensor, the first one close to the headers was still in tact, however the check engine light is not coming off and still unable to crack vtec, anyway to reset the computer? or could i be missing something else, i also took it to auto zone and couple of other shops to do a diagnoses but none of the computer were able to even establish a connection .... any suggestions? it is a really really nice motor bought from Hmo
Old Sep 5, 2007 | 12:37 PM
alien's Avatar
bump... any advice would help
Old Sep 5, 2007 | 12:50 PM
Relic1's Avatar
JDM ECUs will not communicate to USDM code scanners.
which CEL do you have?
which ECU are you using? (P73-003? chipped P28?)
what have you done other than replacing the O2?
have you checked the wiring?
resetting the ECU consists of removing the backup fuse in the underhood fuse box (or removing the ECU from the plugs) for a few seconds.
Old Sep 6, 2007 | 01:38 PM
alien's Avatar
alrite, ) you are a smart head haha, well you make it clear that usdm code scanners wont work, which CEL do i have? i have no clue... as far as the ECU, its the stock 98+ jdm ecu. mm i havent done anything but put a short ram aem intake and a five zigen jdm exhaust system all the way from header, #1 o2 was already there but the top of it is a bit squished, and the #2 o2 i put in myself, there is one vacume line thats left out, i am unsure what it is, some say its the charcoal canister vacume line <- found out yesturday have not had a chance to hook it up becuase the thickness of the hose and the canister thing is much different and im still unsure if that vacume line belongs there or not... ill try reseting the ecu with the simple instructions you gave me
p.s. i did remove both terminals off the battery for about 1 min or so, that didnt do anything
Old Sep 6, 2007 | 02:25 PM
Relic1's Avatar
Default Re: (alien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alien &raquo;</TD></TR><TR><TD CLASS="quote">alrite, ) you are a smart head haha, well you make it clear that usdm code scanners wont work, which CEL do i have? i have no clue... as far as the ECU, its the stock 98+ jdm ecu. mm i havent done anything but put a short ram aem intake and a five zigen jdm exhaust system all the way from header, #1 o2 was already there but the top of it is a bit squished, and the #2 o2 i put in myself, there is one vacume line thats left out, i am unsure what it is, some say its the charcoal canister vacume line &lt;- found out yesturday have not had a chance to hook it up becuase the thickness of the hose and the canister thing is much different and im still unsure if that vacume line belongs there or not... ill try reseting the ecu with the simple instructions you gave me
p.s. i did remove both terminals off the battery for about 1 min or so, that didnt do anything </TD></TR></TABLE>
that's usually not the part of me that people say is smart. lol
check the CELs the same way OBD1 cars do. paperclip and count the flashes (works great on my JDM P73 - check the sticky in the 92-00 forum if you're unsure how to do it)
a pic of the hose and where it goes would help to figure out what it is.
pulling the battery for a minute is more than enough to reset the ECU.
Pull the CEL and go from there.
Old Sep 8, 2007 | 11:03 AM
alien's Avatar
good enough, i will do so, ill snap a pic of the hose ))) thanks a bunch
dices543
Jun 11, 2010 02:47 PM
alien
Sep 10, 2007 06:28 AM
yohan
Sep 26, 2006 02:14 PM
ej2civic
Oct 19, 2004 12:24 PM
roc
May 7, 2003 06:53 PM
