Painting bare metal
Old Sep 3, 2007 | 09:22 PM
siblues's Avatar
Default Painting bare metal
I have a bare roll cage in the car right now.I was just wondering if it would be good enough to just scrub the cage down and then wipe with something like BASF finalwash?I have been told to use a degreaser and then self etch primer.I am going to paint the cage but I want a good primer first to help with adhesion.I also know the primers come in aerosol and brush on types what would be the best products and method to use?Thanks Tony
Old Sep 4, 2007 | 02:19 PM
Pockets's Avatar
yeah wipe it down with the degreaser, spray the etch on it, then you're going to need a non sanding sealer and you're ready to spray your base.
Old Sep 4, 2007 | 03:00 PM
koncept1's Avatar
Default Re: Painting bare metal (siblues)
dont forget wax/grease remover
Old Sep 4, 2007 | 06:40 PM
exvelocity's Avatar
I always have great results using aerosol U-Pol acid etch primer , your bodyshop supply store should carry it
Old Sep 4, 2007 | 08:50 PM
siblues's Avatar
Default Re: (exvelocity)
I picked up some of the self etch primer and what do you guys recommend after that a sealer or just regular primer?Thanks
Old Sep 5, 2007 | 03:40 AM
powerflow's Avatar
Default Re: (siblues)
Seal it then paint it wet on wet. Just flash between coats.
Old Sep 6, 2007 | 07:52 PM
siblues's Avatar
Default Re: (powerflow)
So dont use the self etch then or use it then seal it and paint.Thanks
Old Sep 8, 2007 | 11:27 AM
Pockets's Avatar
etch it, then spray a non sanding sealer on it, then BC, CC.
Old Sep 8, 2007 | 05:01 PM
siblues's Avatar
Default Re: (Pockets)
Great thanks alot
markD.
Paint and Body
Nov 26, 2010 02:09 PM
htsang07
Paint and Body
Jun 11, 2010 04:11 AM
elementskaytr16
Paint and Body
Nov 1, 2007 08:04 PM
torqueless
Jun 5, 2005 09:31 PM
eh-D
Aug 5, 2002 11:30 AM
