can you mismatch cams?
Old Sep 3, 2007 | 06:45 PM
Jonny-X's Avatar
Default can you mismatch cams?
a good friend of mine is putting a CTR intake cam in my jdm b16. he says it will work fine with my stock exhaust cam. and that if i want to do an exhaust cam he has an ITR exhaust cam.. can you mismatch cams like that?
will it be a noticeable power increase?
i have a b16 obd1
intake,header,hollowed out cat and a 2.5 exhaust with n1 muffler.
Old Sep 3, 2007 | 09:38 PM
doood's Avatar
been there done that
Default Re: can you mismatch cams? (Jonny-X)
fyi, itr and ctr exhaust cams are the same thing. there's no problem with that.
Old Sep 3, 2007 | 09:59 PM
H9Omega's Avatar
Default Re: can you mismatch cams? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">fyi, itr and ctr exhaust cams are the same thing. there's no problem with that.</TD></TR></TABLE>
True. But i dont think that is what he's asking. Yes, mismatching cams is fine, in reality you only need the bigger intake cam, but if he has it there, might as well change both but the exhaust cam isnt noticably different from the GSR/B16. Now with the ITR intake cam you would feel a nice little increase.
Old Sep 4, 2007 | 04:55 AM
Jonny-X's Avatar
Default Re: can you mismatch cams? (H9Omega)
ok so the CTR and ITR exhaust cams are the same?
but the CTR and ITR intake cams are different??
and they will both be better than my stock b16 cams?
sorry guys im a bit confused
Old Sep 4, 2007 | 05:57 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny-X &raquo;</TD></TR><TR><TD CLASS="quote">ok so the CTR and ITR exhaust cams are the same?
but the CTR and ITR intake cams are different?? </TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny-X &raquo;</TD></TR><TR><TD CLASS="quote">but the CTR and ITR intake cams are different??</TD></TR></TABLE>
Slight difference between CTR and 97-99 ITR intake cams.
00-01 ITR intake cam=CTR intake cam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny-X &raquo;</TD></TR><TR><TD CLASS="quote">and they will both be better than my stock b16 cams?
Yes.
Old Sep 4, 2007 | 06:15 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: can you mismatch cams? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Yes.
Yes.</TD></TR></TABLE> Yupper.
Back when the cams cost more alot of people would do just what you did, since the cost of parts were higher.
That dated me...
It's A-ok to stagger the cams like that, it'll help a bit power wise.
Old Sep 4, 2007 | 02:12 PM
Jonny-X's Avatar
so should my next mods be a skunk2 intake manifold and TB ?
Old Sep 4, 2007 | 02:53 PM
junkyard racer's Avatar
your putting in the valve springs as well, correct?
To my understanding, thats a must when running anything larger than a GSR cam...on stock B16A valvetrain.
Old Sep 4, 2007 | 04:41 PM
Jonny-X's Avatar
Default Re: (junkyard racer)
really??
i didnt know that..
is this true?
Old Sep 4, 2007 | 06:43 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (Jonny-X)
It def. wont hurt to run a better valve train. You take alot of chance with your stock VT if you plan on revving any higher than stock redline. Plus it's nice to have that insurance.
Old Sep 4, 2007 | 07:39 PM
H9Omega's Avatar
As long as your keeping your 8200 RPM redline, your fine with your stock valvetrain. But down the road, change it out and rev it out.
Old Sep 4, 2007 | 10:54 PM
slow ej1's Avatar
Default Re: (SlammedDC2)
yep
Old Sep 5, 2007 | 04:18 AM
Jonny-X's Avatar
Default Re: (H9Omega)
i do plan on upgrading the valvetrain over the winter while my car is parked.
i would actually like to get the head ported and polished new valves,springns retainers.
what would you guys recomend?
how high can i rev with upgraded valvetrain and the ctr/ itr cams?
and should my next upgrades be an intake manifold and tb?
skunk2 or what?
thanks for all your help so far
ive been out of the honda game since 02 ( i had a 00 epb si) then sold it and got a 01audi s4 dumped probbaly 25k into that car then had a friend wrap it around a pole. since then ive had a son and thats where all of my money has gone.
now i got this 93 coupe **** box ive been working on for the past year and i need to make it faster but i dont want to have to worrie about driving it. maybe a 50shot down the road or possably even a turbo AFTER i get a 2nd vehicle.
Old Sep 5, 2007 | 06:13 AM
blu3g's Avatar
If you're getting upgraded valvetrain then you should be able to rev up to the point and higher than what the ctr/itr cams would make power up to. I would get a tune after you get valvetrain so you know when you stop making power and that should be where you stop revving.
guy_from_nerk
May 4, 2011 09:21 AM
w0nd3r
Jan 16, 2008 07:39 PM
andyboy
Jul 21, 2004 07:29 PM
andyboy
Jul 21, 2004 06:37 PM
SoCaLNaTIvE
Sep 12, 2002 05:49 PM
