Does any know how to adjust Coil Over Suspension?
Old Sep 3, 2007 | 05:56 PM
rpc08's Avatar
Default Does any know how to adjust Coil Over Suspension?
I recently purchased a car with Tein Flex Coil overs but the ride is a little too low. Does anyone know how to adjust the coil overs to raise the height of the car thanks.
Old Sep 3, 2007 | 06:04 PM
JjuuN R's Avatar
Default Re: Does any know how to adjust Coil Over Suspension? (nos86)
You'll need hook tools to pry the perches apart, hope you got them. Jack the car and look at the suspension rather then getting on here and asking a pretty stupid question, it's very very self explanatory...
Old Sep 3, 2007 | 06:43 PM
itr1244's Avatar
Default Re: Does any know how to adjust Coil Over Suspension? (JjuuN R)
lol it's threaded. just turn it and adjust it the way you need it
Old Sep 3, 2007 | 07:02 PM
spock_rocker's Avatar
memoryFAB.com representative
best n00b question ever!! LOL
Old Sep 3, 2007 | 07:44 PM
rpc08's Avatar
Default Re: Does any know how to adjust Coil Over Suspension? (spock_rocker)
just wanted to ask before I mess something up. Never messed with coil overs before. Someone told me you needed a key of some sort?
Old Sep 3, 2007 | 07:47 PM
rpc08's Avatar
where can you get the hook tools?
Old Sep 3, 2007 | 08:07 PM
JjuuN R's Avatar
Should have came with the car, contact the seller...
Old Sep 3, 2007 | 08:18 PM
rpc08's Avatar
if not can i get them somewhere else?
Old Sep 3, 2007 | 08:20 PM
98itRspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nos86 &raquo;</TD></TR><TR><TD CLASS="quote">just wanted to ask before I mess something up. Never messed with coil overs before. Someone told me you needed a key of some sort?
Thats probably for your dampers
Old Sep 3, 2007 | 08:24 PM
JjuuN R's Avatar
Default Re: Does any know how to adjust Coil Over Suspension? (98itRspec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itRspec &raquo;</TD></TR><TR><TD CLASS="quote">
Thats probably for your dampers </TD></TR></TABLE>
Naw, the hooks are also keys...
OP, call Tein or a distributor of theirs, and order some... Jeez...
Old Sep 3, 2007 | 10:30 PM
Parada's Avatar
allright, someone get him a list of distributors
Old Sep 4, 2007 | 12:27 AM
Cheeze's Avatar
Default Re: Does any know how to adjust Coil Over Suspension? (Parada)
If you ordered it from Tein themselves, it would have came with it.
Part # SST01-K0335-B
http://www.tein.com/online_shop/wrench.html
Old Sep 4, 2007 | 11:53 AM
mugenracer's Avatar
Default Re: Does any know how to adjust Coil Over Suspension? (Cheeze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheeze &raquo;</TD></TR><TR><TD CLASS="quote">If you ordered it from Tein themselves, it would have came with it. </TD></TR></TABLE>
read original post
Old Sep 4, 2007 | 12:10 PM
Casey's Avatar
Default Re: Does any know how to adjust Coil Over Suspension? (mugenracer)
you can also tap the perch with a flathead and hammer to knock it lose if you cant find your wrenches. not that i have ever done that or anything??....
Old Sep 4, 2007 | 12:14 PM
JjuuN R's Avatar
Default Re: Does any know how to adjust Coil Over Suspension? (Casey)
That'll work too.
Old Sep 5, 2007 | 05:37 AM
sp00led's Avatar
On my DC2 with Tein RE's it wasn't bad to adjust the front at all. Before you remove the bolt that clamps together the fork on the bottom of the coilover make sure you break loose the ring with the spanner wrench. Otherwise the coilover will spin on you. Once you have the fork loose you should be able to take the threaded bottom peice and lower or raise your car. Once you get it to desired ride height you may need to jack up the rotor/hub assembly to get it back snug into the fork. Then tighten the bolt you had to take loose to adjust the bottom peice. Everything should be tight and you should be good to go. I have to raise/lower my car anytime I run slicks on the track and it definantly gets easier the 2nd/3rd time you do it.
Old Sep 5, 2007 | 07:56 AM
Dave_B's Avatar
The term you are looking for are.... Spanner Wrenches! Not hook tools, and don't use a hammer/screwdriver, you'll just Eff it up...
Get some correct Spanner Wrenches and be done.
Old Sep 5, 2007 | 08:36 AM
rpc08's Avatar
Default Re: (Dave_B)
ordered part from tein. So do you need to do an alignment on the vehicle after lowering or raising car?
Old Sep 5, 2007 | 08:54 AM
Dave_B's Avatar
Default Re: (nos86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nos86 &raquo;</TD></TR><TR><TD CLASS="quote">ordered part from tein. So do you need to do an alignment on the vehicle after lowering or raising car?</TD></TR></TABLE>
Yes, lowering/raising the car changes the geometry.
Old Sep 5, 2007 | 10:22 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, lowering/raising the car changes the geometry.</TD></TR></TABLE>
I also suggest corner weighting Before an alignment.
Old Sep 5, 2007 | 10:27 AM
Dave_B's Avatar
Especially in a track car.
BTW, Anton you cooking was dearly missed at WTDR2... You'd better make 3.
EJ25er
Jan 11, 2013 07:23 AM
wheelspk
Honda S2000
Nov 23, 2010 03:42 AM
MrExclusive
Feb 19, 2010 09:01 AM
Spade
32
Jun 14, 2002 03:28 PM
