Help, 98 LS swap into 97' Ek Hatchback
Old Sep 3, 2007 | 11:39 AM
Adrian G. Aka JDMonkey's Avatar
Default Help, 98 LS swap into 97' Ek Hatchback
Hello guys,
I recently bought a 98' LS swap and it came with
-Engine
-Tranny
-ECU
IT Didnt come with Axles, Shift linkage, Motor Mounts,
My questions are
ANY B-series Shift linkage and axles work?
I need 99-00 SI motor mounts right?
And I want to keep my AC
So exactly what bracket do i need to keep my ac?
Anything else you guys can help me with
any other parts i should get?
Old Sep 3, 2007 | 11:46 AM
flatblack-h22's Avatar
Default Re: Help, 98 LS swap into 97' Ek Hatchback (JDMonkey!)
any bseries linkage and axle should work.
and you need 99-00 si rear tranny mount.
you get a dohc vtec delsol ac bracket to use your dseries ac compressor. also p54 i think off a crv will work,
Old Sep 3, 2007 | 11:47 AM
Default Re: Help, 98 LS swap into 97' Ek Hatchback (Mr.EGG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EGG &raquo;</TD></TR><TR><TD CLASS="quote">any bseries linkage and axle should work.
you get a dohc vtec delsol ac bracket to use your dseries ac compressor. also p54 i think off a crv will work,</TD></TR></TABLE>
Only the 99-00 si Tranny Bracket?
or all 3 engine mounts and tranny?
and p54 off a CRV?
Old Sep 3, 2007 | 11:49 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMonkey! &raquo;</TD></TR><TR><TD CLASS="quote">
and p54 off a CRV?</TD></TR></TABLE>
Just the rear bracket. You'll also need the timing belt cover mount from a CRV (B20Z) so it can hook to your stock driver's side oil-filled mount.
Old Sep 3, 2007 | 11:52 AM
Default Re: Help, 98 LS swap into 97' Ek Hatchback (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
Just the rear bracket. You'll also need the timing belt cover mount from a CRV (B20Z) so it can hook to your stock driver's side oil-filled mount.</TD></TR></TABLE>
So i can use my stock Ek mounts? and ONLY need the rear tranny mount?
Old Sep 3, 2007 | 11:55 AM
Eran's Avatar
HT White Ops
Yes. I used my stock front torque mount, my stock transmission torque mount, a 99-00 EM1 rear tranny mount, my stock oil-filled mount, and a 2000 CRV timing-belt-cover mount (two bolt).
Old Sep 3, 2007 | 11:56 AM
duggy's Avatar
P54 is not the CRV bracket. P7J is.
Old Sep 3, 2007 | 11:57 AM
duggy's Avatar
You can use the stock EK Driver side mount, but you need to get a bracket that bolts up to the block from a 99-00 SI.
You need the 99-00 SI rear Transmission T-Bracket.
Old Sep 3, 2007 | 11:58 AM
Yes. I used my stock front torque mount, my stock transmission torque mount, a 99-00 EM1 rear tranny mount, my stock oil-filled mount, and a 2000 CRV timing-belt-cover mount (two bolt).</TD></TR></TABLE>
you have an ek too? well, what you said makes it simple, thank you
Old Sep 3, 2007 | 11:59 AM
Default Re: Help, 98 LS swap into 97' Ek Hatchback (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy &raquo;</TD></TR><TR><TD CLASS="quote">
You need the 99-00 SI rear Transmission T-Bracket.</TD></TR></TABLE>
The bracket for what?
Old Sep 3, 2007 | 12:00 PM
Eran's Avatar
HT White Ops
The bracket for what?</TD></TR></TABLE>
He's saying that an EM1 timing-belt-cover mount will work as well, since it is two-bolt.
Old Sep 3, 2007 | 12:01 PM
He's saying that an EM1 timing-belt-cover mount will work as well, since it is two-bolt.</TD></TR></TABLE>
oohh ok, thank you all
made my day much easier
Old Sep 3, 2007 | 12:03 PM
duggy's Avatar
I guess I made it too complicated =|
Old Sep 3, 2007 | 12:58 PM
Default Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy &raquo;</TD></TR><TR><TD CLASS="quote">I guess I made it too complicated =|</TD></TR></TABLE>
and I thought girls were complicatd
jk bro, its all good, thank you much love you long time
Sep 9, 2007 10:12 AM
Sep 5, 2007 11:00 PM
Sep 3, 2007 09:51 PM
nuklang
Aug 6, 2006 08:05 PM
1.8
12
Dec 18, 2004 06:36 PM
