gas RMP error revmeter fluctuations
Old Sep 3, 2007 | 11:38 AM
TURKISHFORCE's Avatar
Default gas RMP error revmeter fluctuations
hi all, my ef9 vtec in has in hot mode fluctuations from 1000RMP to 300RMP like a ping pong ball ore jumping frog..
in coold motor ist all ok allright...
i have change lots of thinks but no improvement..
eavc cleanly made..
neu map senssor..
butterfly valve cleanly..
lamda probe change.
new cooling water..
new battery..lima makes 14,5 volt its ok..
new cooling water sensor..
new gasoline filter..
neu spark plugs..
new wire spark kable..
new walbro gas pump 250ml..
amusingly is wen i put the cable plug from the eavc make off, (with engine on) and put it 10 sec again on,after the aktion is my rev fluctuation away and all is ok 800RMP
for one stays...
help please
so ne scheisse..
http://images.google.de/imgres...a%3DN
Old Sep 3, 2007 | 11:56 AM
slowcivic2k's Avatar
Default Re: gas RMP error revmeter fluctuations (TURKISHFORCE)
Might need to set base idle.
Idle the car to fully warm, and unplug the EACV. If the car stalls, check your PCV system for a clog. If the PCV system is alright, then adjust the idle screw on the throttle body until it idles at 450RPM. (yes I know that is a shitty idle speed, but that is the engines base idle without the EACV) Then plug in the EACV, and your idle should be as specified.
Old Sep 5, 2007 | 09:13 AM
Default Re: gas RMP error revmeter fluctuations (slowcivic2k)
what is the pvc???
unplug eavc makes nothing,rmp is the same,when i adjust on the idle srew trottle down,i cant not make low rmp under 900 rmp??? i close the idle screw trottle body ,and rmp still 900 rmp...
allways is all right with rmp for 1 ore 2 days ,other days cames the rmp fluctuations.
Old Sep 5, 2007 | 12:33 PM
JimBlake's Avatar
If you cannot make the idle go below 900 with the IACV unplugged, then you may have a vacuum leak. Check gaskets, hoses, anyplace air can leak into the intake manifold.
Old Sep 6, 2007 | 07:36 AM
Default Re: gas RMP error revmeter fluctuations (JimBlake)
no leak... all is ok ,psi gauge is corect and vacum testing on all pgfi ore hose are all right..
i CAN make low rmp when all is on (wire cable)input from the eavc ,put without eavc plug goas nothing..
gasoline safety device under leaking driving wheel in car make sound like klick-klick-klick all 4 sec.. witout eavc wires
i test next time without rmp fluctions...
maybe i mast reset the ecu-battery after the neu rmp installing adjust...
Old Sep 6, 2007 | 08:04 AM
JimBlake's Avatar
I'm having a language problem... sorry. I hope I can help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURKISHFORCE &raquo;</TD></TR><TR><TD CLASS="quote">i CAN make low rmp when all is on (wire cable)input from the eavc ,put without eavc plug goas nothing.. </TD></TR></TABLE>
Do you mean the engine stalls (dies) when you unplug the IACV? If so, you can use the throttle to keep it going while you adjust the idle needle valve. The final goal is 450rpm while NOT holding the throttle open.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURKISHFORCE &raquo;</TD></TR><TR><TD CLASS="quote">gasoline safety device under leaking driving wheel in car make sound like klick-klick-klick all 4 sec.. witout eavc wires</TD></TR></TABLE>I don't understand that at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURKISHFORCE &raquo;</TD></TR><TR><TD CLASS="quote">maybe i mast reset the ecu-battery after the neu rmp installing adjust...
Yes, after you adjust the base idle, here's the procedure.
1 - Plug the wire back into the IACV.
2 - Disconnect battery (reset the ECU).
3 - Let it cool down.
4 - Start the engine without touching the gas pedal AT ALL.
5 - Let it idle and warm up completely without touching the gas pedal.
Old Sep 6, 2007 | 09:45 AM
2 - Disconnect battery (reset the ECU). with during motor on?? ore must make motor off (out)?
thanks for info..
http://209.85.135.104/search?q...gl=de
this is the gasoline safety device under driving wheel for ??gas benzin gasoline..main safety device chip????
http://images.google.de/imgres...a%3DG
Old Sep 6, 2007 | 10:29 AM
JimBlake's Avatar
Switch the car completely OFF before disconnecting the battery.
I'm not sure about the other stuff in those links. (I'm 1/2 German, but I can't read any of it.) Maybe something installed in Europe but not in USA? Maybe it shuts down the fuel pump during an emergency?
Old Sep 7, 2007 | 04:35 AM
super ok, 2 days a go and rmp runs normal and safty..
thanks...
sstupid
20
Aug 18, 2016 06:46 PM
toshko321
Oct 18, 2009 07:15 AM
95ex
15
Feb 4, 2007 04:19 PM
stehigs321
28
Feb 11, 2004 01:06 AM
kingpen
Aug 31, 2002 09:27 PM
