turn over but no start?
Old Jun 14, 2002 | 11:22 PM
speedlimitR's Avatar
Default turn over but no start?
i have a side car, its a 89 civic 4 door LX.
and it turns over. but its does not start up. and i dont thing it is spark or fuel.
what could it be, it has stared before. but just will not now. has had this problem
since i got it. any ideas?
please? thank you!!!
Old Jun 14, 2002 | 11:49 PM
Trinity's Avatar
Default Re: turn over but no start? (speedlimitR)
well its either the starter or spark or fuel. how do you know its getting spark?
Old Jun 15, 2002 | 12:17 AM
Default Re: turn over but no start? (Trinity)
well, i dont think its the starter, because its turning over, and if it was the started, it woudl not turn right?
Old Jun 15, 2002 | 04:41 AM
Trinity's Avatar
i had a bad started and it tried to start it just wouldn't. how do you know u are getting spark
Old Jun 15, 2002 | 08:14 AM
kyler's Avatar
try these:
-pull spark plug, put plug back in boot and have a friend crank while you hold it about 1/8" away from the valve cover... see a spark? if no check the rotor and or ignitor
-put that part the way it was... next turn on key and listen for the click of the mainrelay down by the hood pop followed by the whirr of the fuel pump, if no.. resolder/replace the main relay...
-next tug the timing belt cover and make sure that mug didn't snap
hth,
K.
Old Jun 15, 2002 | 09:28 PM
ProTreeCRX's Avatar
could be alot of things. try starting it with one crank. by this i mean let it turn over once. and then try it again. keep trying it. and then try starting it with multiple cranks. make sure you dont flood your engine. did you feel any lag when you drive this car?
Old Jun 16, 2002 | 06:47 PM
Griffins_Importuning's Avatar
Default Re: turn over but no start? (MnC CRX)
i would say try your main relay. located under the dash. it controls spark and fuel in your car. give it a shot. either that or a bad ecu. or a bad ground....check your thermostat ground and your starter ground....
Old Jun 16, 2002 | 06:57 PM
island_son's Avatar
Default Re: turn over but no start? (Griffins_Importuning)
It might be your coil
Old Jun 16, 2002 | 07:36 PM
FourthGenHatch's Avatar
Yeah!
Is it really hot outside? The old kind of Main Relay would fail under extreme heat and your car wouldn't start. Mine did this. I got a new one and they are made better now and I no longer have this problem.
The symptom is that the car will crank and everything will seem fine but it just won't start. The Main Relay sends the signal to the fuel pump and injectors to turn on.
When you turn the key can you hear the fuel pump come on? If not than it is probably this.
It's $41 at the dealer.
Old Jun 17, 2002 | 12:08 AM
Magick211's Avatar
Default Re: turn over but no start? (FourthGenHatch)
He said the motor is turning over so it coudnt be the starter.
civic2sick
Feb 26, 2020 09:39 PM
GTFODave
Mar 24, 2010 06:14 AM
Keno20
Jan 26, 2009 10:10 PM
Abs777
Feb 7, 2008 08:53 PM
