i traded for a p28???
Old Sep 2, 2007 | 07:47 PM
rmriffle's Avatar
Default i traded for a p28???
i have a 94 hatch with a d15b with the stock p06 ecu i was told it would not hit vtec with that i traded for a stock p28 out of a 93 del sol it had a d16z6 but he said the 93 delsols dont hit vtec but it had a vtec selinoid what is the deal on this?? i put it in and i think it hits vtec but im not sure it is still a d series so you prob cant here it.. let me know thanks
Old Sep 3, 2007 | 04:02 AM
eg6sittingon57cs's Avatar
Default Re: i traded for a p28??? (rmriffle)
z6 has vtec just on the exhaust side
Old Sep 3, 2007 | 05:04 AM
97Ej6mike's Avatar
Default Re: i traded for a p28??? (eg6sittingon57cs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sittingon57cs &raquo;</TD></TR><TR><TD CLASS="quote">z6 has vtec just on the exhaust side </TD></TR></TABLE>
Old Sep 3, 2007 | 09:59 PM
doood's Avatar
been there done that
intake. and what does that have to do with the original question?
to the OP, it's a sohc 1.6l. dont expect to feel vtec.
Old Sep 3, 2007 | 10:04 PM
USDMCIVICHATCH's Avatar
Default Re: i traded for a p28??? (doood)
if you had a 92 eg it would be plug and play because all 92's are prewired for vtec but you have a 94 so unless it is an Si shell you'll also have to run vtec wires to the ecu for it to work. Do you have a check engine light on?
Old Sep 3, 2007 | 10:11 PM
rmriffle's Avatar
Default Re: i traded for a p28??? (USDMCIVICHATCH)
no it does not trough a check engine light. the stock motor that came in my car was a vtec motor it was a vx..i think
Old Sep 3, 2007 | 10:20 PM
if it is a vx then I would do a search on vx motor swaps. they require additional wiring that a cx/dx/si doesn't, because the vx had a vtec-e engine which is not anything like a real vtec engine
Jorsher
Mar 24, 2007 03:21 PM
xsi_racer
Dec 4, 2006 10:48 AM
ej_vtec
11
Oct 22, 2006 10:56 AM
northkai3
26
Jul 10, 2005 06:56 PM
KiDSoL
18
Oct 3, 2003 10:38 PM
