Help installing shocks and Springs on front
Old Jun 14, 2002 | 10:45 PM
Renegade's Avatar
Default Help installing shocks and Springs on front
I could not remove the damper fork-to-lower control arm bolt if my life depended on it.
Any tips or techniques?
If I need a compressor, I was thinking of buying one anyways, I've seen a 2HP 5gallon and a 5HP 10 gallon ~$168 I think, what would be the smallest one I could get to do most jobs?
Thanks
Old Jun 14, 2002 | 10:53 PM
uNF$@#!'s Avatar
Default Re: Help installing shocks and Springs on front (98401R)
put your arm into it. you really dont need to remove anything but the shock itself.
if you think youre having problems with the front wait until you get to the rear LCA bolt
Old Jun 14, 2002 | 10:56 PM
Aoi-Zip's Avatar
spray some WD-40 on it... and use a wrench to pull the bolt out while you unscrew w/ your ratchet...
[Modified by Aoi-Zip, 11:57 PM 6/14/2002]
Old Jun 15, 2002 | 04:14 AM
Cosworth's Avatar
First question: Do you have Helm's manual?
-if yes, then forget this question.
Second question: Are you trying to take out the damper folk and shock as a unit?
-You should be able to slide down the LCA so that there's room to take out the shock. Once the shock is out, then you go ahead and take out the folk.
Old Jun 15, 2002 | 05:47 AM
brwnrice's Avatar
Default Re: Help installing shocks and Springs on front (Cosworth)
if your in san diego i can give you a hand
Old Jun 15, 2002 | 07:12 AM
smeister's Avatar
Default Re: Help installing shocks and Springs on front (Aoi-Zip)
Don't use WD-40...Use Gunk Liquid Wrenck...also get a breaker bar or custom one out somehow...hth
Old Jun 15, 2002 | 07:55 AM
Renegade's Avatar
Default Re: Help installing shocks and Springs on front (smeister)
I am in CA, bay area.
I never think about the breaker bar, I will try that although it makes it hard because there is no good angle to use it, I will need to lift the car really high. I'll try it.
I am trying to move the fork so I can take out the shock and springs.
Do I really really need to take off or at least take the bolts of the stab bar? it doesn't seem like I do.
I don't have helms I have Haynes basically the same thing.
Thanks
[Modified by 98401R, 4:56 PM 6/15/2002]
[Modified by 98401R, 4:59 PM 6/15/2002]
Old Jun 15, 2002 | 12:08 PM
Renegade's Avatar
Default Re: Help installing shocks and Springs on front (sackdz)
it works well for removing and installing shocks and springs....
I got everything off, I bought an extender and that did it.
Now the problem is the Damper mounting base does not fit into the shock rod.
Anyone installed GC/Konis before?
Old Jun 15, 2002 | 01:17 PM
Warren's Avatar
Wrong-Way Wang
Well, first thing's first. You won't get anywhere if you're using a 3/8" wrench. You NEED to use a 1/2" (edit: with at least a 15" handle). It doesn't need to be that high. I usually have the car sitting on the bottom setting, or the next to bottom setting on jackstands.
Warren
[Modified by Warren, 5:18 PM 6/15/2002]
Old Jun 15, 2002 | 06:38 PM
Renegade's Avatar
Default Re: Help installing shocks and Springs on front (Warren)
I just dremeled the mounting base holes to the size of the Koni rods, everything is in and I took it for a ride, its a huge difference, I knew it would be better but I did not expect this much better
Old Jun 15, 2002 | 09:20 PM
Asahi's Avatar
HEAT! Get a torch.
Old Jun 15, 2002 | 11:01 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Help installing shocks and Springs on front (Asahi)
IMO, the blue wrench shouldn't be necessary for this project
Warren
96 EX
38
May 22, 2009 02:18 AM
soodominican
May 11, 2008 11:25 AM
Ax3l
Suspension & Brakes
Jul 18, 2005 12:53 PM
rdaggett
26
Apr 12, 2005 09:37 AM
Got Utensils
11
Mar 10, 2004 06:37 PM
