how to check distributor?
Old Sep 2, 2007 | 01:00 PM
preludepower01's Avatar
Default how to check distributor?
I have a 01 Honda prelude and i am getting a miss fire i was told it could be my distributor (i did change the spark plugs and wires but it did not fix it timing is ok to)
thanks
Old Sep 2, 2007 | 01:30 PM
96vtecI4's Avatar
Take it off and check for build up in there. Scrape any off with a flat head, see if that helps any.
Old Sep 2, 2007 | 02:59 PM
JasonST's Avatar
Default Re: (96vtecI4)
How bad is it misfiring? Is it 1 cylinder or all of them? Did u check to see if ur getting spark to all cylinders? Any other noticeable problems?
Old Sep 2, 2007 | 03:37 PM
Default Re: (JasonST)
well the code said it was 1 and 3 and the miss is not that bad ( it only happened in lo rpm) i think. what seems to happen is that when i am not moving that's when it happens but when i am moving it all seems ok
Old Sep 3, 2007 | 07:58 AM
lude98SH's Avatar
Default Re: (preludepower01)
if your misfiring it could be one in a million things. Best way to narrow it down is a 5 gas machine. That will tell you if its a mixture problem or its a problem in your secondary ignition circuit.
Old Sep 3, 2007 | 08:07 AM
bluedlude's Avatar
Default Re: (lude98SH)
wow.... or you could just open the distributor, check out the cap and rotor. if all looks good, check the distributor circuits themselves. if thats good, check the coil although its likely the distributor. BTW, ive got an OBD2 distributor i need to get rid of
EsCo_EsCo
Sep 29, 2008 08:25 AM
Ryan124
10
Apr 17, 2006 10:20 PM
IlsCrx
Mar 28, 2006 05:50 PM
Brian_92GSR
May 21, 2002 04:46 PM
