intercooler piping crx/full-race traction bar fitment
I just got the full-race traction bar on my crx but the lower intrercooler pipe wont work with the radius arm on it, its right in the way of the blow off valve.. any suggestions? i dont want to spend a lot on a welder either, maybe just rent a mig weld gun and make it myself? even though i know nothing about welding. And i cant possbily wait another week to get this thing going, so i want to avoid ordering new pipes.
Can you turn the compressor housing up and have your piping go that way? What manifold, how is your piping routed, which way is the compessor inlet? Give more info
Try facing the comp. housing up (assuming it is on the drivers side). You'll need to run the hot side up and out the bay through the hole by the overflow tank.
Its a b16 in a 89 crx with a full race kit... it looks like the manifold is in the way if i turn the compressor up, ill try it tonight when i go home and see if it looks good, then i still have to order a new pipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef dino »</TD></TR><TR><TD CLASS="quote">Its a b16 in a 89 crx with a full race kit... it looks like the manifold is in the way if i turn the compressor up, ill try it tonight when i go home and see if it looks good, then i still have to order a new pipe
So it is the driver side piping you are having probs with? Post some pics
</TD></TR></TABLE>So it is the driver side piping you are having probs with? Post some pics
adictionbass
Dec 30, 2004 04:10 PM
