Crimping Thick Wires onto Ring Connectors?
Old Jun 14, 2002 | 08:33 PM
Tommy_Gunns's Avatar
Default Crimping Thick Wires onto Ring Connectors?
What do you guys use to crimp 0-4 gauge wire? I went to several audio shops and electronic stores and found nothing.
Old Jun 14, 2002 | 08:47 PM
Default Re: Crimping Thick Wires onto Ring Connectors? (Tommy_Gunns)
I found a way, but I'd like to hear other people's idea's as well.
Old Jun 14, 2002 | 09:06 PM
dc24me's Avatar
In the install bay, we have these big *** crimpers that weigh a good 15-20 lbs or so. You put the ring terminal in this 4 sided thingy and squeeze and works for anything from 0-8 gauge.
I have seen this metal tap thing before where the middle is shaped like a V. On top is another V but it's upside down. You stick the terminal ring in and you bang on the top with a mallet. It's sort like a vise but would surround the crimp 360 degrees.
I don't know if any of this helps.... You could use a pair of visegrips or look into those crimpless ring terminals.
Have you looked at Home Depot? I looked though the ratshack catalog but couldn't find anything
Old Jun 14, 2002 | 09:53 PM
92AccordCoupe's Avatar
Default Re: Crimping Thick Wires onto Ring Connectors? (dc24me)
partsexpress.com carries this item...but it's kinda expensive.
Old Jun 15, 2002 | 11:04 AM
ME's Avatar
ME
Default Re: Crimping Thick Wires onto Ring Connectors? (92AccordCoupe)
You can also use the kind without insulation and solder it with a propane torch. The big thing is to get a gas-tight joint that won't corrode over time.
Liquidgsr
Audio / Security / Video
Apr 15, 2005 10:12 PM
CrazyModGSR
21
Jul 15, 2004 07:09 PM
KiNG $h!t
Feb 23, 2004 09:53 AM
Origin
15
Feb 18, 2004 08:14 AM
Jsracingintegra
Oct 30, 2002 06:29 AM
