Can I retorque new leaking headgasket? many questions....HELP!
Old Sep 1, 2007 | 08:18 PM
spidermancivic's Avatar
Default Can I retorque new leaking headgasket? many questions....HELP!
i put in my new headgasket on my d16y7 and it is now leaking a little. tested my old harbor frieght torque wrench against my neighbors craftsman torque wrench and the difference between the two is by 16 ft lbs thats what i get for trusting in HF. question here is..................can i just retorque with the craftsman? the only thing the new headgasket has experienced is about 30 mins of idling.
also, if i retorque, do i still need cylinder one at TDC? and can i retorque 10 ft lbs past oem specs since it has already experienced a leak? still on used oem head bolts.
TIA HT.
Old Sep 1, 2007 | 08:32 PM
ke98248's Avatar
Default Re: Can I retorque new leaking headgasket? many questions....HELP! (spidermancivic)
You'll want to stay at OEM torque specs.
Take the head-gasket off and put some gasket sealer on there.. You'll also want to make sure the gasket is perfectly flush and that it mates up 100%.
Old Sep 1, 2007 | 09:35 PM
Crx Jimmy's Avatar
Default Re: Can I retorque new leaking headgasket? many questions....HELP! (ke98248)
you can take the gasket off and spray it with copper gasket spray
Old Sep 1, 2007 | 10:15 PM
da_dude's Avatar
I would just retroque it down first and see what happen before taking the head off again. And it doesn't need to be TDC for you to retroque the head.
Old Sep 2, 2007 | 04:16 AM
ShortyzKustomz's Avatar
That scares me now, I used a Harbor Freight clicker on my last motor build...No leaking and I sold the truck as it was lol
Old Sep 2, 2007 | 05:37 AM
racehesh's Avatar
Default Re: (ShortyzKustomz)
Was your head warped? Did you check it? Something else to look at.
Old Sep 2, 2007 | 06:59 AM
jtfc3s's Avatar
yup i bought a torque wrench for HF too and that thing is not really that accurate..
Old Dec 29, 2009 | 04:13 PM
lexluther's Avatar
Does that copper spray work??... or is it a cheat?..
Old Dec 29, 2009 | 04:48 PM
green99civic's Avatar
Agree wouldn't go through all the trouble to find out just re torquing them and then you could be good! Cause then after that if it still leaks, then new head bolts yes because they have already been stretched! Head gasket can depend on how many miles were on it
Old Dec 29, 2009 | 06:28 PM
gotslicks's Avatar
warped thread.lol
Old Dec 29, 2009 | 08:18 PM
itsnotfast's Avatar
I would try re-torquing them first but I would go like 3 ft/lbs past OEM specs. If it still leaks, I would pull the head off and have the head checked and replace the head gasket. I would never re-use a head gasket that has been torqued already.
Old Dec 30, 2009 | 06:11 AM
dbb95ex's Avatar
This is why I spend a little extra on good tools, especially when you're working on cars or other high dollar items. I'd re-torque then run it for 20-30min. Then keep a good eye on it over the next few weeks if it's good. If not pull the head check to make sure it's level and the block is as well. Did you make sure to get all the old gasket off?
Old Dec 30, 2009 | 09:31 AM
supra-n-civic's Avatar
did you ahve the head milled and prep your surface. if not take it part and do so no question . if you dotn mill the head then you will have a problem. but that being said if you DID do those things then go ahead and re tourque. in the correct pattern as well. and try it. if it dosnt work tear it down get a enw head gasket and start over the RIGHT way. i woudl tear it town unless the retorque dosnt work. and use stock tq specs when using stock stuff.
Old Dec 30, 2009 | 09:43 AM
newtron63h's Avatar
get a new head bolt set, replacing one at a time and snugging it down, then once you get all new ones in, retorque in proper sequence(idk if you have the sequence but its basically starting in the center and working your way out) if this works then great. if not, get a new gasket and bolt set, have your head checked out and fixed if needed, then try it again.
Old Dec 30, 2009 | 10:58 AM
jooky5's Avatar
NEVER use HF for anything that needs to be accurate.
hammers, screwdrivers, socket wrenches are ok. No micrometers, scales, or torque wrenches
Freshdot
Oct 17, 2012 03:43 AM
ITR.#1446
Jul 22, 2008 01:45 AM
MelloYelloCRX
Jun 30, 2007 09:30 PM
*Boostwerks*
Feb 25, 2005 10:48 AM
tremor86
Jul 3, 2004 03:14 PM
