help me with rebuilding b18c1 (pic my ride)
hey guys! I got a 95 civic si with a 95gsr engine in it. I want to take a class in college that I can rebuild an engine. I did some research on honda tech and did not find much about rebuilding a gsr engine. I need to know wich pistons. rings, connecting rods,capsw,berrings,cams,valves, springs I need to put to later run 8-15 pounds of boost? Do I need to lower the compression? THANX
http://i180.photobucket.com/al...3.jpg
https://honda-tech.com/zeroforum/16
you're not searching very hard if you cant find people's setups running that kind of boost
If you plan on boosting and you don't even know if high or low compression is best, then you really should take the college course and then post a question that your professor can't answer.
Luckily enough Honda engines are some of the easiest to work on. What are your power goals for the car? and what is your budge? Do your home work and building this engine will be a pleasure. but if you don't it can turn into a nightmare really fast.
YellowCivic95
Apr 27, 2002 07:59 AM
. they can help u better. for you
