will this work(cheap climate control)
Old Jun 14, 2002 | 07:21 PM
DOMKID's Avatar
Default will this work(cheap climate control)
EDIT
Modified by Dominican_Kid at 4:02 PM 7/1/2003
Old Jun 14, 2002 | 07:29 PM
TurboBumblBee's Avatar
Default Re: will this work(cheap climate control) (Dominican_Kid)
from what i have heard and read online it will not work as easily as you think.. i dont own a 6gen civic but have read before about this and its not plug and play as you may think.. anyone else know for sure????
Old Jun 14, 2002 | 08:30 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: will this work(cheap climate control) (95CivicEX)
I had an attempt to do that mod, it's NOT worth it. I know the 99-00 console looks cool and all but it's a totally different wiring setup. The 96-98 are cable driven and 99-00 ones are electrical. So even if you do get it in, you probably won't have A/C.
Old Jun 14, 2002 | 09:23 PM
tonyxcom's Avatar
Default Re: will this work(cheap climate control) (GapxGuy)
I have talked about this swap many times and was going to do it myself....until I found out what all needed to be swapped/modded.
To keep a long story short. DONT BOTHER.
It is a pretty much plug and play swap with very little modding.... IF YOU HAVE THE ENTIRE DASH, the heater box, the blower motor etc etc.
Old Jun 15, 2002 | 12:49 AM
DOMKID's Avatar
Default Re: will this work(cheap climate control) (tonyxcom)
thanks for the info guys, i appreciate it.
Old Jun 15, 2002 | 05:23 PM
confidence's Avatar
i had a 99 ac consol in my old car
what we did was cut off the top part that has the ac vents and mold on the 96 vents into it. we filled the space where the ac controlls went with tweeters and i just moved my ac controlls down above the cup holder. it worked quit well.
at first the ac controlls by the cup holder were annoying but i got used to it. it will help a lot if you get the metal shell that houses the radio out of the 99+ civic too. it will keep your radio and stuff from moving around
i will try to find the pics of it
one more thing, the reason we had to cut off part of the 99 peice is that the ac vents on the 99 and the 9c won't line up. it was easier to cut the top off and add another one than take apart the entire dash just to change out 3 peice of plastic
[Modified by snail, 2:28 AM 6/16/2002]
hondapeeler
Audio / Security / Video
Nov 29, 2010 03:55 PM
baozer
Aug 9, 2006 04:54 PM
92siracer
Dec 19, 2003 05:50 AM
Unjockable
16
Feb 21, 2002 12:11 PM
Halo
10
Feb 1, 2002 12:30 AM
