Overheating problem....
Old Jun 14, 2002 | 07:04 PM
bigmike's Avatar
Default Overheating problem....
Okay my problem is this .... the temp guage in my car will jump all over the place. I will be driving normally then it will slowly raise all the way to the red. I have plenty of coolant, oil, and the rad fan works. If i turn on the heat in the car the temp will go back down to its normal range, right in the middle of the guage. Now it is summer time so i dont' want to have the heat on all the time. If i check the engine while the guage is in the red, it doesn't seem too hot at all.
any suggestions on how i can fix this ?
thanx
Old Jun 14, 2002 | 07:44 PM
Civikun1945's Avatar
New User
Default Re: Overheating problem.... (bigmike)
try checking the thermostat. Maybe it is opening up on a spontanious manner....which will be very werid.....
Old Jun 14, 2002 | 08:14 PM
Mike P.'s Avatar
25 Year Member
Default Re: Overheating problem.... (Civikun1945)
sounds like the thermostat simply isn't really opening. The temp goes down while driving at a higher speed, right?
Also, sounds like it may be the original thermostat. That sounds about right since it's a '93. Even if you don't need a new one, it wouldn't hurt to replace it and the radiator cap...both of 'em are cheap insurance.
[Modified by Mike P., 12:17 AM 6/15/2002]
sno
Dec 28, 2004 01:24 AM
rdaggett
Aug 11, 2004 12:48 PM
Art Vandeleigh
Jun 29, 2004 07:19 PM
iH8RICERZ
Feb 3, 2004 12:59 PM
zzzkenji
Apr 23, 2003 06:06 PM
