Correct break in procedure for rebuilt bottom end?
Old Jun 14, 2002 | 06:53 PM
B19CivicHB's Avatar
Default Correct break in procedure for rebuilt bottom end?
I'll be getting my shortblock back from the machine shop in a week. It'll have new pistons, rings, rods, bearings, wrist pins and seals. The clutch (in-organic) and flywheel will be new too. I've heard 500 miles of stop and go granny driving for the clutch\flywheel. Ive heard max 3000 rpm for 200 miles, then up rpm limit by 1000 for each 200 miles after until 1000 miles for the internals to seat\break in properly. Does this sound correct? Thanks!
-Nick-
Old Jun 14, 2002 | 07:33 PM
deez92's Avatar
Default Re: Correct break in procedure for rebuilt bottom end? (B19CivicHB)
500 miles and very the rpm's, i wouldn't stay in high rpm's for long either, just be nice to it
Old Jun 14, 2002 | 07:38 PM
B19CivicHB's Avatar
Default Re: Correct break in procedure for rebuilt bottom end? (deez92)
500 miles for both clutch and bottom end?
Old Jun 14, 2002 | 10:27 PM
builthatch's Avatar
MiG-21 superfan
if the build is done correctly, 150 miles is all you should need, as per the crew chief of Bergenholtz racing and head tech at pactell engine management, NATHAN TASUKON. With r&d at gude, tech at AEBS, and his present positions, I don't doubt his wrd one bit...BUT, It's up to you; 2000 miles, broken into 4 sections of 500 miles with an 5w-30 conventinal oil change after every stage is what i do with all my builds, to catch any problems before they become disastrous...first 500 miles <4000rpm, change oil...next 500 miles <6000rpm, change oil....next 500 miles <7000rpm change oil, next 500 <9000 rpm, change oil, it's def overkill but hoo cares? what is the rush, for the peace of mind!
[Modified by builthatch, 2:30 AM 6/15/2002]
[Modified by builthatch, 1:27 PM 6/15/2002]
Old Jun 15, 2002 | 06:03 AM
deez92's Avatar
Default Re: Correct break in procedure for rebuilt bottom end? (builthatch)
yes both
Old Jun 15, 2002 | 12:52 PM
Rocket's Avatar
Use non-detergent oil. It's good stuff for ring seal.
Old Jun 15, 2002 | 12:59 PM
B19CivicHB's Avatar
Default Re: Correct break in procedure for rebuilt bottom end? (Rocket)
alright, thanks for the input guys!
WILD_WILL
Honda Civic (2006 - 2015)
83
Apr 21, 2007 01:35 AM
Nextelbuddy
Feb 27, 2004 06:08 AM
ipath22
Aug 13, 2003 08:53 AM
JsMaVisD
Jun 24, 2002 02:34 PM
threatcon13
Feb 2, 2002 01:14 AM
