my headlights are dirty whats the best to clean it.
Old Sep 1, 2007 | 11:32 AM
vtek9's Avatar
Default my headlights are dirty whats the best to clean it.
my headlights are dirty from the inside and the outside. whats the best way to clean it and what producst would you guys suggest?
Old Sep 1, 2007 | 11:42 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: my headlights are dirty whats the best to clean it. (vtek9)
Mothers Plastic Polish I believe is what it's called...
Old Sep 1, 2007 | 11:43 AM
SleeperGSR's Avatar
a rag and this stuff called elbow grease
Old Sep 1, 2007 | 01:30 PM
redDAinteg's Avatar
Default Re: my headlights are dirty whats the best to clean it. (SleeperGSR)
eagle one never dull
Old Sep 1, 2007 | 01:35 PM
tegG2's Avatar
Default Re: my headlights are dirty whats the best to clean it. (redDAinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">eagle one never dull</TD></TR></TABLE>
I wouldn't use never dull unless its really bad and you have tried everything else. The chemical is a litter harder on the plastic. Maguires or mothers plastic polish will do the trick.
Old Sep 1, 2007 | 01:40 PM
redDAinteg's Avatar
Default Re: my headlights are dirty whats the best to clean it. (tegG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegG2 &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't use never dull unless its really bad and you have tried everything else. The chemical is a litter harder on the plastic. Maguires or mothers plastic polish will do the trick. </TD></TR></TABLE>
I usually just use wax and it keeps it shiny. I just said eagle one never dull because I saw the article on http://www.team-integra.net .
How well does the mothers plastic polish work ? Any before and after pics ?
Old Sep 1, 2007 | 02:28 PM
keeks707's Avatar
Meguiar's Plast -X. ....that stuff really works....i saved lots of money because i was about to buy new head lights!
Old Sep 1, 2007 | 02:31 PM
SleeperGSR's Avatar
you can use regular car polish. you don't need anything fancy. I've heard toothpast works too.
Old Sep 1, 2007 | 03:09 PM
alexisthemovie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">you can use regular car polish. you don't need anything fancy. I've heard toothpast works too. </TD></TR></TABLE>
toothpaste works as a filler. to really cut the layer of yellow/dirt, you need a plastic polish like meguiar's plastx. a few minutes under the heat of my porter cable and it's good as new.
Old Sep 1, 2007 | 04:19 PM
Spugen69's Avatar
take 2000 grit and wet sand. it sounds scrary but it really hard to mess up if you just use 2000. then let it dry and polish with Meguires PlastX just follow the instructions on the bottle and ur lights will look close to brand new. Also did this on my 89 Ranger cleaned them right up and they were so oxidized that it was pointless to turn the headlights on.
Old Sep 1, 2007 | 05:31 PM
stuie08's Avatar
well i am a detailer, and personally i like to use Meguiar's Plastix.
or even a fine buffing compound.
best way is if you have a buffer, a small on and use the meguiars. but by hand it works very well also.
Old Sep 1, 2007 | 07:36 PM
Haiderade's Avatar
PlastX
Old Sep 1, 2007 | 07:50 PM
vtek9's Avatar
Default Re: (Haiderade)
thanks guys, ill propabaly get a bottle of that tomorrow at kragen. how do you clean the inside of the lens? do i gotta take the whole headlight off?
Old Sep 2, 2007 | 12:51 PM
GhOSt_Db8's Avatar
i suggest that you use some sort of wax that does the trick.
Old Sep 4, 2007 | 08:28 AM
b18_integra's Avatar
believe it or not WD-40 works
Old Sep 4, 2007 | 09:55 AM
Default Re: (GhOSt_Db8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhOSt_Db8 &raquo;</TD></TR><TR><TD CLASS="quote">i suggest that you use some sort of wax that does the trick. </TD></TR></TABLE>
wax has no stripping/cleaning power so it will not work.
Old Sep 4, 2007 | 10:24 AM
iwantturbo's Avatar
Default Re: (alexisthemovie)
kit scratch remover works wonders, especially with headlights. i do mine every month
foowitdaredek
12
Oct 29, 2007 05:46 PM
DFW
Jan 14, 2006 09:21 PM
rabvtec
Jun 28, 2005 01:28 AM
Spade
46
Jul 29, 2004 10:04 AM
raene
15
Jun 8, 2003 04:56 PM
