acceptable to tack (weld) a loose arp wheel stud?
ok I have arp extended wheel studs and noticed that one is loose. It isn't fully striped and at this point I can take my lug off. It does however "wiggle" so I am thinking I just tack it in a couple spots and problem solved. What do you experienced people think?
Please don't comment if you don't know what your talking about. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">that's fine, just put a nut on it to pull it tight in the hub and weld the back side of it. </TD></TR></TABLE>
Good info
I had to do the same
Good info
I would feel safer using loctite's slip fit locking compound stuff. Any heat-treatable steel can get brittle after welding and crack. If you do weld it, it is a good idea to hit the welded area with a torch until it glows a dull red. This tempers the material back to not being brittle.
Kevin
Kevin
2.2L EH2
24
Mar 19, 2022 03:40 PM
gakkuken
21
Jan 10, 2005 02:28 PM
