Catching trans mount
Im in the process of installing the motor and im having a hell of a time getting this trans mount in. Its not a matter of lining it up it just bolting it up since the bracket on the trans is directly in front of the bolts on the frame so i cant get it in. There has to be some trick to doing it anyone have any ideas ?
when you lower the engine into the bay, tilt the trans side down some to clear the mount, then you can get the mount on there, just don't bolt it down yet, then try to get the drivers side mount lined up without bashing the crank pulley on the frame
My 93 accord
May 12, 2016 11:10 PM
