Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
emanage ultimate
Old Aug 31, 2007 | 05:57 PM
DJaeMac's Avatar
Default emanage ultimate
will the emanage ultimate be good enough to hand 350 whp?...
and is it safer than the emanage?
Old Aug 31, 2007 | 06:35 PM
Boilermaker1's Avatar
its still a signal modifier. This is 2007... use a stand alone.
Can it do it? Yeah, I guess, but you're just going to be fooling the stock ECU into doing things. You dont really have great control over it. Especially with closed loop feedback.
Old Aug 31, 2007 | 08:57 PM
DJaeMac's Avatar
Default Re: (Boilermaker1)
other than the kpro unit and the cam gear, what else will i need cuz i change some sensors when i used the e-manage
im really on a budget this time....
im only 18 and its hard to cough up some money...ha....
since the motor is being built, i rather be safe and go with a good fuel management....
Old Aug 31, 2007 | 09:19 PM
Hondata uses all the factory sensors. if you want to go over 10 psi, you'll need a 3bar map sensor, as the stocker will only read up to 9.8 psi.
Old Aug 31, 2007 | 09:47 PM
kuki22's Avatar
u could also use teh 2.5 bar form greddy
Old Sep 1, 2007 | 12:42 AM
DJaeMac's Avatar
do i have to call hondata to order?..and will i have to send out my old ecu?
BioXide02
Jun 30, 2005 01:53 PM
S2KP
Nov 27, 2003 06:09 AM
94dxt
Apr 25, 2003 05:21 PM
hybrid901
Feb 6, 2002 07:22 PM
BlwnBlue
Aug 11, 2001 06:32 PM
