z6 into AWD wagon questions
The AWD wagon uses an intermeidate shaft and equal length axles. Does a z6 block have the mounting locations for an AWD intermediate shaft?
I know the AWD a6 motors have different oilpans that CRX a6 motors. Can I use a stock z6 oilpan with the AWD transmission?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abram_quito »</TD></TR><TR><TD CLASS="quote">no they are totally different
if u refer to your 84 -95 chiltons book
the jack shaft
are not even the same
one is longer and other is shorter
CRX a6 have no jack shaft
AWD do have a jack shaft</TD></TR></TABLE>
lol. we know they are different. he is asking if the z6 block has the threaded holes
the jack shaft
i am almost 100% positive that the holes are there but contain no threads and need to be tapped. And would it be possible to use the wagon intermediate shaft on a regular crx si tranny or does it have the larger axles like the zc tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by #1nismo »</TD></TR><TR><TD CLASS="quote">its not threaded the holes are there, is the wagon intermediate shaft axle teh same as a regular 88-91 driver side axle spline wise though?</TD></TR></TABLE>
You can't use a regular axle in a differential that takes an intermediate shaft. There is no provision for the circlip to snap in and hold the axle shaft in the diff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by #1nismo »</TD></TR><TR><TD CLASS="quote"> And would it be possible to use the wagon intermediate shaft on a regular crx si tranny or does it have the larger axles like the zc tranny?</TD></TR></TABLE>the wagon with the intermediate shaft uses the larger diameter axles - the intermediate shaft won't fit into an Si transmission
three stars, two bars
Aug 23, 2007 08:51 PM
96MidoriHatch
Dec 14, 2004 06:22 PM
biassj
May 16, 2003 03:57 AM
