HELP!!!
I just bought a 97 civic EX with a B16 (obd1) . When I bought it it kept throwing a code . The knock sensor was not wired up, so it got wired up and now the car bogs down all through the power band. The car is undriveable its so bad. I adjusted the ignition timing and no change, replaced the fuel filter and it got a little better but still undriveable. Thats where Im at if anyone can help please do.
can you describe a little better what it is doing that makes it undriveable?
is it constantly bogging? or only bogging at certain rpm's? any more information you can think of. this is a really general thing to be looking for help at this point
did the car run fine when you bought it? as in everything was wired correctly? I would check the blue wires on the distributor first. But if you used to run fine, that wouldn't really make sense.
If it improved with a fuel filter, I would check other stuff. Run some fuel injector cleaner maybe, it sounds like it could not have been well maintained before. Who knows?
k20rsx1
19
Jun 5, 2009 02:30 PM
knightnam
Jul 30, 2005 03:07 PM
