Steering column shifts left and right..
Like the title says, my steering column shifts left and right about 1/4 - 1/2 inch and I was wondering if that is a big problem or will lead to bigger ones.
I haven't seen inside a Honda steering column, but I'd imagine it's secured with bolts above the cover. Check to see if the bolts are backing out. Steering is something you shouldn't take chances with.
there are bolts under the dash that hold the column in place. just take the plastic out under the dash and look up and you will see them.
