weird clutch feel when releasin...
ok, when the car is off it does not do this!
whenever i let up on the clutch, in nuetral or in gear, it drives perfectly fine but its rubbing/grinding and it didnt always do that...its been getting worse and i want to fix this problem before something may happen....
any suggestions? any help is appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie »</TD></TR><TR><TD CLASS="quote">clutch = manual</TD></TR></TABLE>
You do know automatic transmissions have multiply clutch disc inside them right
After re-reading it, I see he was talking about a manual.
oook, it's a 97' integra ls with 123,000 miles on it...when pressing down there is no noise but when releasin up from ground 1/4 inch it's a weak click and when the clutch cathes around halfway up, it does the same thing weaker and for a little bit longer
turnsignalandy
14
Aug 22, 2006 07:13 AM
greddytointegrate
Oct 6, 2005 03:03 PM
Nameless RB26
Dec 3, 2002 03:41 PM
