crank pulley
Old Jun 14, 2002 | 04:03 PM
ryu12341's Avatar
Default crank pulley
Whats the best way to take the crank pulley off a d16z6? I've tried impact wrench, and sticking a screw driver between flywheel holes and bell housing. It's on way too tight. It's not reversed threaded is it/ Thanks...
Old Jun 14, 2002 | 08:16 PM
bearingburner's Avatar
Default Re: crank pulley (ryu12341)
oh yeah..... that thing is on hella tight.
the best way to do that is to use a 3/4" impact gun.
well that's what i use. i know many of the portable air compressors are not strong enough to loosen it. another way is to use a breaker bar with maybe a jack handle leverage and a pulley holder from a company called OTC. you can ask a mac tools truck for that tool
Old Jun 14, 2002 | 08:21 PM
ryu12341's Avatar
Default Re: crank pulley (bearingburner)
My compressor has 135 psi max-stand up craftsman 6 hp. I still think it's too weak though. How does that pulley holder work? does anybody else that you know of stock it. I work at Sears service Center, so I can get good discounts on craftsman stuff at the retail store. Do you know if Craftsman makes that? Thanks though for the info. Would it be a bad idea to stick a block between the inside of the block and a rod, to keep it from rotating? Thanks
[Modified by ryu12341, 5:22 AM 6/15/2002]
Old Jun 14, 2002 | 11:38 PM
salbaje's Avatar
get a crank pulley tool.
kojack_0
12
Apr 23, 2008 06:09 AM
SlowPokeEg
Nov 24, 2007 09:50 PM
budomove
Nov 2, 2007 07:26 AM
xxmastermindxx
Aug 22, 2006 09:22 PM
95lstegman
Mar 8, 2005 10:12 AM
