Header 4-2-1 or 4-1 designed..
Old Aug 31, 2007 | 05:49 AM
crazyguy's Avatar
Default Header 4-2-1 or 4-1 designed..
i cant remember which designed 4-2-1 or 4-1 is for more high end torque, both are one piece design and for daily drive basis, which one is more suitable for street drive?thanks
Old Aug 31, 2007 | 05:52 AM
Syndacate's Avatar
Default Re: Header 4-2-1 or 4-1 designed.. (crazyguy)
4-2-1 is more suitable for street drive. 4-1 makes all its power up high.
Old Aug 31, 2007 | 05:56 AM
crazyguy's Avatar
Default Re: Header 4-2-1 or 4-1 designed.. (Syndacate)
thanks dude. u the man
Old Aug 31, 2007 | 08:13 AM
ke98248's Avatar
Neither does much on a SOHC or DOHC tho. Just in case you're thinking of buying one. I did, and it's a big waste, besides the temporary (hella expensive0 bling factor until my pieced together turbo kit is installed.
Old Aug 31, 2007 | 08:17 AM
crazyguy's Avatar
Default Re: Header 4-2-1 or 4-1 designed.. (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Neither does much on a SOHC or DOHC tho. Just in case you're thinking of buying one. I did, and it's a big waste, besides the temporary (hella expensive0 bling factor until my pieced together turbo kit is installed.</TD></TR></TABLE>
yea i know it will not do any performance gain .but my stock header is cracked. thats why i am looking to buy one.
Old Aug 31, 2007 | 08:18 AM
ke98248's Avatar
get a $65 ebay one then. It really does do give you performance gains, just not enough to warrant spending the $$ it costs. I know multiple people that have the egay header and it looks nice and works fine, no cracks/leaks. That's probably one of the few things I'd suggest people buy from ebay
95ProjectEJ1's Avatar
You are in So Cal, hit up the So Cal marketplace for a used stock one. I would much rather spend 30-60 then to use the cracked one as an excuse to spend 300+ ya know?
Old Aug 31, 2007 | 08:19 AM
ke98248's Avatar
Default Re: Header 4-2-1 or 4-1 designed.. (95ProjectEJ1)
new Egay header FTW
Old Aug 31, 2007 | 08:33 AM
HondamanXxX's Avatar
GO GIANTS!
I run a Ebay 2.5 outlet 4-2-1 Header on GSR until I boost it. 4-2-1 two piece and also comes with gaskets. Not a bad deal for 65 dollars.
Old Aug 31, 2007 | 08:53 AM
tha_badguy's Avatar
get an edelbrock header!
$100+ for a quality header
Old Aug 31, 2007 | 09:15 AM
DCSportEJ1Civic's Avatar
Default Re: (tha_badguy)
an ebay header is just goin to crack eventually. id find a stock one.
Old Aug 31, 2007 | 09:27 AM
ke98248's Avatar
Default Re: (DCSportEJ1Civic)
Unless you've had personal experience with the ebay headers, I wouldn't speak up. They've been proven to be quite reliable.
Old Aug 31, 2007 | 09:56 AM
Default Re: (ke98248)
ahh here we go again. friends of mine do have experiance with them. and usually bad ones. im not sayin dont buy one but w/e. i have a dcsport header and im pretty happy with it. all im sayin is id go for a used stock mani before an ebay header.
Old Aug 31, 2007 | 12:50 PM
Shaun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Unless you've had personal experience with the ebay headers, I wouldn't speak up. They've been proven to be quite reliable.</TD></TR></TABLE>
uhhhh , I have experience with them and it cost me 120$ of labor for nothing becuase its had exhaust leaks around the head.... ebay header
Old Aug 31, 2007 | 12:52 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Shaun)
Get a megan header. And modify the collector to a 2.5" pipe. You'll have a bangin' DIY header.
Old Aug 31, 2007 | 01:08 PM
smileycvc's Avatar
Are you serious. Maybe on a stock motor it might not make a huge change, but it will help your power. If you start to build the motor a 4-2-1 or 4-1 are going to be the best header style you can go with. That why all custom headers are 4-2-1 or 4-1 design. On d-series it wont matter what you do short of a turbo set up. On a b series though your results will be alot diffrent.
Old Aug 31, 2007 | 02:27 PM
doood's Avatar
been there done that
Default Re: Header 4-2-1 or 4-1 designed.. (smileycvc)
get a tri-y 4-2-1. best of both worlds.
Old Aug 31, 2007 | 03:34 PM
bballchris24's Avatar
i like the 4-1
994door
16
Oct 25, 2007 07:37 PM
sundownz
Nov 9, 2006 10:15 AM
Jaysun
Mar 6, 2005 12:01 PM
trooper0641
Apr 14, 2004 12:57 PM
Synergy001
13
Sep 3, 2003 11:13 AM
