VTEC Solenoid and Coolant Temp Sensor??????
Old Jun 14, 2002 | 02:38 PM
AK94GSR's Avatar
Default VTEC Solenoid and Coolant Temp Sensor??????
Can someone confirm that these 2 plugs look the same?? I am still having the problem with those engine codes. I am at work and not able to check myself. So if you are by your car could you please check and let me know. Can't wait I need to know if they look the same??
Old Jun 14, 2002 | 04:15 PM
erniecars's Avatar
Default Re: VTEC Solenoid and Coolant Temp Sensor?????? (AK94GSR)
the do look pretty much the same except the coolant temp sensor is a white plug in the head and the vtec solenoid is a green plug on the vtec solenoid
Old Jun 17, 2002 | 11:14 AM
AK94GSR's Avatar
Default Re: VTEC Solenoid and Coolant Temp Sensor?????? (erniecars)
Has anyone ever thrown one of these codes???? If so what was causing the problem?
If anyone has any suggestions please post. I hate ECU codes
924doorEG
Jan 15, 2009 11:22 PM
thermostate82
Nov 6, 2008 08:24 PM
BEATINTEGRA
Dec 5, 2007 03:05 PM
iCONxEG21
Nov 22, 2007 11:00 PM
mikebranson
Apr 13, 2004 09:00 PM
