d15b crank in d16a6 block
Old Aug 29, 2007 | 07:06 PM
1000kg88hb's Avatar
Default d15b crank in d16a6 block
I want to know is it possible to put a d15b2 crank in to a d16a6 bolck if so could i use d16 rods and pistons. i've had a great deal of experience with both motors in cars and it is my opinion that the d16 has a great deal more torque but it top end after 5800 it takes a dive plus when i do the build on my car for big numbers i want to give up my low end for traction with street tires. my experiences with the d15 is its power wants to go clear to the redline. that just my experience with obd 0 motors.
Old Aug 30, 2007 | 08:09 AM
Bense's Avatar
main journals are smaller on the d15 crank. d15b2 crank also has smaller rod journals.
jdm d15b crank has larger rod journals (like a d16)
Old Aug 31, 2007 | 03:15 PM
1000kg88hb's Avatar
Default Re: (Bense)
thanks for the info so if you don't mind what is the stoke diff of the jdm d15b and usdm d15b&b2 if any at all
BraveHeartSOHC
Jan 11, 2014 11:38 PM
Bense
Sep 5, 2007 02:10 PM
oi101
Oct 26, 2005 09:29 PM
Br1anPham
Oct 5, 2004 08:42 AM
