Oil in the spark plug "boot"
Old Aug 29, 2007 | 01:10 PM
kabhatti's Avatar
Default Oil in the spark plug "boot"
I did a quick search, didn't find it so here goes. On a 92 accord ex, 4 cyl engine, when changing the plugs, why is there oil on the wrench and boot of the spark plug cable? Is that a sign of bad valve guides?
Thanks,
KB
Old Aug 29, 2007 | 01:13 PM
wickedintegra's Avatar
Default Re: Oil in the spark plug "boot" (kabhatti)
change your valve cover gasket, it comes with the big gasket and 4 small gaskets that go on each of the spark plug holes.
Old Aug 29, 2007 | 01:23 PM
kabhatti's Avatar
Default Re: Oil in the spark plug "boot" (wickedintegra)
So it sounds not serious at all, thanks much!
Old Aug 29, 2007 | 01:35 PM
Honda-Master's Avatar
here you go
https://honda-tech.com/zerothread/2082872
Old Aug 29, 2007 | 04:21 PM
Bruce Banner's Avatar
Default Re: Oil in the spark plug "boot" (Honda-Master)
replace o ring seals.
Old Aug 29, 2007 | 05:34 PM
kabhatti's Avatar
Default Re: Oil in the spark plug "boot" (Bruce Banner)
Thanks to all the great responses everyone. I'll be hanging around here quite a bit since I just bought the car, it has 218K miles on it and seemed to be maintained fairly well.
I do notice that it seems to have a constant miss when cruising on highway speeds. It idles fine and steady. I've just changed the plugs with ngk and a new set of wires. I'm planning on having the timing belt done shortly. I reckon what's left is the distributor cap, fuel filter and maybe fuel injection???
Thanks again folks!
KB
koulninja
12
Aug 1, 2011 08:51 PM
1998_4dr_gsr
Apr 13, 2011 09:02 AM
matryx
Dec 15, 2007 01:18 PM
BB6racer
Jan 18, 2006 05:20 PM
fasteddy91
Apr 4, 2003 08:43 AM
