Help Check Engine Light is on !!
Old Aug 28, 2007 | 11:25 PM
bluecivic11's Avatar
Default Help Check Engine Light is on !!
I pulled CEL code 22 and 41 on h22a P13 ecu. Code 22 is VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch. Code 41 is Primary Oxygen Sensor - Heater circuit malfunction. What is the best way to troubleshoot these 2 codes? Should i just replace the Vtec Oil pressure switch? or the oil pressure switch? or What should i do ? Please point me in the right direction. I am really poor right now and cant afford to take it to a shop. Thank you very much in advance.
Old Aug 29, 2007 | 03:23 AM
mgags7's Avatar
you probably need a new o2 sensor, though it could have been a fluke.
reset the ecu and see if they come back (just unplug the black battery terminal for about 30 sec)
Old Aug 29, 2007 | 01:13 PM
Default Re: (mgags7)
I will do that today when i get home. What about code 22? What should i do? Thanks again.
Old Aug 29, 2007 | 01:21 PM
98vtec's Avatar
moderator emeritus
Default Re: (bluecivic11)
take the vtec solenoid off and clean it. If that doesnt fix the issue, you need to replace the sensor. The sensor may be a part of the solenoid tho so you may have to replace the whole thing.
Old Aug 29, 2007 | 03:50 PM
Default Re: (98vtec)
By how exactly should i clean it? Sorry to sound so dumb...but im clueless.
The sensor is a green plug correct?
My oil pan is dented...could this also be the problem ? Thanks.
Modified by bluecivic11 at 5:09 PM 8/29/2007
Old Aug 29, 2007 | 04:02 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluecivic11 &raquo;</TD></TR><TR><TD CLASS="quote">By how exactly should i clean it? Sorry to sound so dumb...but im clueless.
My oil pan is dented...could this also be the problem ? Thanks.</TD></TR></TABLE>
yes. yes.
unbolt it and spray it with brake cleaner to make sure the screen is clean. Dry out and reinstall.
Old Aug 30, 2007 | 08:03 AM
Thanks. gonna do that right now.
Old Aug 30, 2007 | 11:16 AM
guessman's Avatar
i'm just checking but do you have a dented oil pan? that can sometime cause problems with the oil pressure.
Old Aug 30, 2007 | 11:17 AM
98vtec's Avatar
moderator emeritus
Modified by bluecivic11 at 5:09 PM 8/29/2007</TD></TR></TABLE>
read the thread before posting.
Old Aug 30, 2007 | 06:56 PM
Heres a pic of my oil pan. Should i replace it? It looks pretty bad huh? Oil Pan
Oil Pan 2
Thanks guys.
Modified by bluecivic11 at 8:13 PM 8/30/2007
Old Aug 30, 2007 | 07:19 PM
98vtec's Avatar
moderator emeritus
um....yea dude. Fix your ****.
Old Aug 30, 2007 | 07:51 PM
flyrod's Avatar
So... how did you place in that rally? Any footage?
Old Aug 30, 2007 | 09:24 PM
Default Re: (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">So... how did you place in that rally? Any footage?</TD></TR></TABLE>
rally?
Old Aug 31, 2007 | 11:20 AM
Damn... oil pan/gasket costs around $150. Anyone know a dismantler for honda? Maybe i can get a used one. Thanks.
Old Sep 3, 2007 | 06:28 PM
preludepimpin8668's Avatar
Default Hey gotta problem
hey i got an 86 honda prelude 2.0 fuel injected and it wont start, the fuel pump went and then i changed it and it wont start all it does is turn over and the first time i turn it over it will start and rev up to about 2000rpm and then quit then it will just turn over i heard it cud be a bad battery feed to the injectors but im not sure got any info for me? --
preludefien
Feb 11, 2007 10:43 AM
vtec93accord
Nov 3, 2003 08:09 PM
shonnys92si
Jan 20, 2003 11:45 PM
89Civic
Jun 10, 2002 12:16 PM
lsvtec42
Mar 8, 2002 04:01 PM
