90 dx making really wierd noise
Old Aug 28, 2007 | 09:30 PM
00EKcivic55's Avatar
Default 90 dx making really wierd noise
I got a 1990 Civic dx hatch all stock. it ran good after i cleaned the battery and i only noticed one thing. when i reversed it made a wierd grinding noise, but all other gears it sounded fine. today i backed out the mall and it kept doing that noise, but when i shift and accelerate it sounds normal but if i let off the gas it does it again, or when im idling you can hear and feel it.
SOMEONE PLEASE HELPP
thanks!
Old Aug 28, 2007 | 09:35 PM
B18c1vicrx's Avatar
so it grinds only when being put into reverse, AND when your on the clutch in a gear?
Old Aug 29, 2007 | 01:03 AM
EFin' Kyle's Avatar
Default Re: (B18c1vicrx)
throwout bearing? i know when my throwout bearing went bad a while back it sounded kinda like a soft grinding/whining noise. just an idea. =P hope if all works out for ya
-Kyle
Old Aug 29, 2007 | 05:40 AM
no it does it all the time, but it only used to do it in reverse, so ithought it might be the tranny, or something in between the tranny and engine, like flywheel or pessure plate or something like that.. the engine sounds normal when i give it gas its like it snaps out of it or something, but if i let the pedal off it goes back to it... please helllp
Old Aug 29, 2007 | 05:53 AM
juanchoenuncrx's Avatar
* B A N N E D *
Default Re: (00EKcivic55)
yeah it might be the flywheel that is broken or something like that but that doesnt have anything to do with battery
Old Aug 29, 2007 | 06:26 AM
Default Re: (juanchoenuncrx)
i never said it was anythin to do with the battery.. it once had a dead battery, and i got it running. hahaha, now it grinds hella bad, and it also feels like the tranny movs around when i shift it, i can feel it moving through the shifter!
Old Aug 29, 2007 | 09:19 AM
B18c1vicrx's Avatar
this is happening with a friend of mine with a 240 kinda, it grinds into a few gears and when he hits the clutch and leaves it in gear it'll grind the hell out of it...i believe his problem is a cracked pressure plate, just a suggestion, not a solution
Old Aug 29, 2007 | 10:27 AM
hybrid1990crx's Avatar
Default Re: 90 dx making really wierd noise (00EKcivic55)
can you explain this grinding noise some more. you are saying it goes into reverse ok but when you start moving its grinding? are you sure its all the way in gear? also maybe you are mixing up a whine with a grind. Reverse gears in older hondas are straight cut and often have a loud whine to them.
if you started doing it in forward gears you might want to check your trans fluid, maybe it is low, and in turn your bearings are falling apart.
Old Aug 29, 2007 | 08:50 PM
Default Re: 90 dx making really wierd noise (hybrid1990crx)
well, i had a honda genius look at my hatch, and low and behold it is a broken trnny mount! not that it took a genius to figure it out but it was something i overlooked... i didnt notice the left side of the engine sittin way lower than the right!, 3 inches lower!!! so i purchased a d15b and 4 speed tranny and all mountsfrom buddy for 50 bucks!!! so if any of you need a d banger that runs ill be able to sell it.. im cleaning it up as it is dirty as a cows *******...
fabmaster
Jul 16, 2010 08:06 PM
eh9deux
Apr 13, 2010 09:58 AM
fleaEG
Oct 18, 2007 02:34 PM
Platinum.Skillz
Oct 2, 2007 09:35 AM
JokerX-1.6T
14
Apr 5, 2007 11:33 AM
