compression check help
Old Aug 28, 2007 | 07:50 PM
souljah_jon's Avatar
Default compression check help
I did a compression check which reads:
cylinder 1: 0
cylinder 2: 180
cylinder 3: 155
cylinder 4: 155
99 honda si
any help on whats wrong?
car cant start...
Old Aug 29, 2007 | 09:28 AM
ddd4114's Avatar
Default Re: compression check help (souljah_jon)
What happened that prompted you to run the compression test (aside from the car not starting)? The fluid in cylinder 1 must be going somewhere...
What was done to the car?
Old Aug 29, 2007 | 06:19 PM
Default Re: compression check help (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">What happened that prompted you to run the compression test (aside from the car not starting)? The fluid in cylinder 1 must be going somewhere...
What was done to the car?</TD></TR></TABLE>
I did the compression test already. thats done. i just need
help on why is cylinder 1 at 0 when i did the test.
Old Aug 29, 2007 | 06:22 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by souljah_jon &raquo;</TD></TR><TR><TD CLASS="quote">I did the compression test already. thats done. </TD></TR></TABLE>
No... haha
I meant what modifications have you done to the car...
Old Aug 29, 2007 | 06:46 PM
drtysohc's Avatar
what happened when it stopped running? it could be a number of things, bent valves, hole in a piston, thrown rod, melted piston or a combination of things. It could also be that you did the compression test wrong.
Old Aug 29, 2007 | 10:12 PM
No... haha
I meant what modifications have you done to the car...</TD></TR></TABLE>
98 civic, si motor. aftermarket intake, exhaust
Old Aug 29, 2007 | 10:16 PM
Default Re: (drtysohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drtysohc &raquo;</TD></TR><TR><TD CLASS="quote">what happened when it stopped running? it could be a number of things, bent valves, hole in a piston, thrown rod, melted piston or a combination of things. It could also be that you did the compression test wrong.</TD></TR></TABLE>
the car almost died on me when i was driving on the road. i had to pull over
cuz it was dying. but then i turn it back on. luckily i was a few mins away
from home.
but yah it could be a number of things.
- timing
- whole in piston
i dont do engine work so i dont know.
how much will it cost to replace a piston???
I would think it would be wise to replace all 4...
Brandon Peters
Oct 18, 2015 05:37 PM
chuisek9
Sep 9, 2007 11:01 PM
rich045
Jun 13, 2007 12:23 PM
Amused
Oct 26, 2006 03:30 AM
SikITR01-248
Apr 24, 2005 03:46 PM
